| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#161 |
For D1V33, it is less susceptible to oscillation and thus no shielding is required if electrolytic Bi Polar capacitor is used. Personally I like Nichicon BP Electrolytic capacitors as they are cheap and good.
#162 |
Good news ! Thanks !
#163 |
The original D1 use 18 bit data mode from CS8414 to SM5842. Thus it is not optimise for 24bit data signal.
I have done an upgrade so that the D1V3 and D1V33 can use 24 bit data file with better results. See link below: http://www.fetaudio.com/?p=576 |
#164 |
Some update in fetaudio regarding using 96k Fs and AD1862 DAC in D1 platform.
http://www.fetaudio.com/ |
#165 |
I've just started to build your DAC Is there any build thread ? Thanks for your nice packaging |
#166 |
I believe everything is in below links:
http://www.fetaudio.com/?p=112 http://www.fetaudio.com/?p=101 |
#167 |
Hi Spencer,
I am wondering if it would be possible to use an external clock on the D1V33. I read a post (number 4 in this thread) but it was the D1V3. Is it still possible on the D1V33 ? Actually I'd like to have a masterclock for both the DAC and my CD drive. Thanks for your halp. PS : BTW my dac is working, your assembly manual was most helpful. I doubted to be able to mount it but it went smoothly following the instructions
#168 |
See here : FET Audio » D1V33 with external super clock 256Fs
D1V33 use master clock at 256 Fs. Fs maximum 48kHz for SM5842 and 96kHz for SM5847. |
#169 |
Recently I tried RIFA PEG124 100u/100V on the 4 output capacitors and the sonic performance is very good. Silmic II has been used and it is also better than Muse BP and the sound is a bit silky and soft. PEG124 give the highest dynamics in all frequency and is a very good capacitor for signal coupling in this DAC. Choose the capacitor that suit your sonic taste preference.
#170 |
Hi Spencer,
I have some LM140LAH lying around and am considering to use them in lieu of the LT1117 since they may be quieter. Is this feasible? Last edited by housing; 12th February 2010 at 08:16 AM. |
| Does anyone ever use enhancement-mode devices? | keantoken | Solid State | 4 | 19th January 2009 10:52 AM |
| System Enhancement Help | Victoria | Subwoofers | 1 | 12th January 2006 09:47 AM |
| Active Crossover And Sound Enhancement Units | set | Chip Amps | 1 | 12th January 2005 11:32 AM |
| SubWoofer Enhancement | Negative Design | Analogue Source | 0 | 31st December 2003 05:50 AM |
| Page generated in 0.11207 seconds (79.02% PHP - 20.98% MySQL) with 11 queries |
