Mad About Sound
Review of mic pre-amp kit
I ordered a mic preamp kit & capsule, which arrived yesterday.
The kit is well thought out and the PCB is really high quality and easy to solder to. My connection at home is down so I've printed the instructions at work today and should finish the kit this evening with any luck. Everything is so crystal-clear with photos to show how it should look even I shouldn't blow this up.
It may be worth noting on the template sheet that default Adobe Reader printer settings shrink-to-fit so page-scaling must be set to "none". Otherwise the 5mm hole on the template is smaller than 5mm, etc.
I can't wait to do some measurements on my new open baffle experiment.
Simon
