| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#631 | |
Guys, I understand the kit did not meet your expectations, and I know it's a bummer when something doesn't work as you expect it to. But this type of circuit behaves differently under different circumstances. In some instances it appears to be very sensitive to parasitic capacitance, as with you. As I understand from previous posts, Mikkel has not encountered this problem like this before.
On his website, he never promises 100% attenuation or no clicks, because in his applications this clearly wasn't an issue, as for many other people. He promises 64 dB of attenuation, or more if you use larger steps. With this type of circuit, 100% attenuation can only be reached by full muting (relay). If you want more without a muting relay, it is possible to recalculate your resistors with for example larger steps. However some of you deem it neccesary to portrait him in a very negative way, even if he is clearly trying to help with the issue. I was just hoping we could constructively search for a solution. Quote:
But nevermind, onto possible solutions: This forum describes the same circuit and forum post 71 and further they discuss some possible solutions for the clicks: -Fixed L-pad after the last relay -Different timing (possibly with dual coil relais) Constant impedance relay-resistor logarithmic attenuator Together with the remarks on Pinkfish, maybe Mikkel could look into the timing of the switching... Did you recalculate the other resistors as well, or only changed the input resistor? |
#632 | |
"Some lures are designed to catch fish, others are designed to catch fisherman." |
#633 |
Mikkel
Please check my PM. I'm having great difficulties with the Rem-1 boards and I need your help to resolve this, Thanks Yair |
#634 |
Mfly,
I've only tried changing out the input resistor, I have a vary limited experience with electronics so I try not to change things I don't understand. Personally I don't mind not going to 0 volume at -64dB, mine is VERY quiet at that setting, like a whisper. OK by me. My only complaint is the clicks at volume changes. I guess I should have know about relay devices causing clicks, but I'm an admitted noob. I have never intended to dis or Bash Mikkel or his equipment / kits. I've only tried to share my experiences with others who may be considering buying this kit and are not aware of the possible clicks. MIkkel, Thank you for looking into the issues that we have encountered with your kit. By building a tube preamp to test your Vol1 kit shows your professionalism and commitment to the quality of your kits. Thank you. I hope you are able to duplicate our issues in your test lab. We appreciate that you are checking this forum / thread more often, again showing that you really DO care about customer service. I doubt you make much $$$ (if anything) from your kits, so it's a service to those of us who do not have the talent to design our own. Don't take any of our post personally Mikkel, I think we all like you. Thanks, Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 Last edited by Renron; 28th January 2010 at 05:52 PM. Reason: clarity |
#635 | ||
Time is a bit of a problem right now, but I hope I'll have some time during the weekend. Best regards, Mikkel C. Simonsen |
#636 |
Thank you Mikkel,
We appreciate you trying to help us, all of us. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 |
#637 |
MIkkel, also the other versions of your attenuator can not reach volume zero?
#638 | |
#639 | |
Can the VolControl3 board and it's LCD display be used with the ChipVol1? Perhaps there is no need to reinvent the wheel ? Just change the tire? Ron
#640 | |
| Page generated in 0.14340 seconds (81.53% PHP - 18.47% MySQL) with 11 queries |
