Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th December 2009, 12:11 AM   #551
piero7 is offline piero7  Italy
piero7's Avatar
Originally Posted by Renron View Post
Hell yes there's DC. It powers the board!
Nothing in front of it but an Oppo BDP-83 and John Broskie's Aikido tube board after it.
Changed to High quality 100K resistors and now I don't get 0 volume either!
I'm with ya Piero7.......now where's my hammer???
Ron
Yo renron, I'm still waiting for the relays...
For the hammer, be patience
Old 15th December 2009, 04:38 AM   #552
mcs is offline mcs  Denmark
Originally Posted by piero7 View Post
DC in the path?
Yes, there's sometimes a DC off-set on the output of signal sources. This causes clicks when the DC is connected/disconnected by an attenuator.
Why didn't you state on your site that you controller can not full muting? Have you even seen a volume controller that can not reach volume zero?
You can reach -63dB, if the attenuator is connected and loaded correctly. That is volume zero in my system. With a 2V input signal you get about 1mV out at -63dB. If the loading is not correct, you don't get the -63dBs.
Which preamp do you have connected to the output of the attenuator? Do you have a schematic?
Why dind't you reply to my mails? I have payed money for your volume control pal...
Sorry. I had work problems (real work - not audio) that left me no time to even read e-mail. I have to pay the rent every month no matter how many (or few) of my customers pay me what they owe...
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 15th December 2009, 04:46 AM   #553
No idea if an Oppo has a DC-offset on the output. Do you have a link to the schematic of your preamp? I find Broskie's site a bit confusing
If I have the parts, I could try to duplicate the problem...
You shouldn't get 0 volume. But if you get -63dB, that should be very close to 0, unless you have huge amps and horn speakers
Best regards,
Mikkel C. Simonsen
Old 15th December 2009, 05:45 AM   #554
Renron is offline Renron  United States
Renron's Avatar
Mikkel,
You have always been a good guy, IMO.
at -63dB it should be 0 , zero, rein, nada.
I have 6.5" midwoofers no horns and a very old Haffler DH200 amp. (100W)
-63 is louder than a whisper, if I want silence I have to mute it.
I'm OK with the volume not being zero at -63, but the clicks embarrass the hell out of me. That's why I did not take it to "The Burning Amp 3" this year.
I'll try to find out where the DC is coming from. I'll let you know if I find anything out.
I like you Mikkel, check back here more often please.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
Old 15th December 2009, 12:22 PM   #555
piero7's Avatar
Best regards,
Mikkel C. Simonsen
Mikkel, I also have the Broskie's Aikido with 4XE80CC, and my DAC has transformers output (give a look to the post here "experience with this dac" with galvanic isolation primary/secondary and I can assure you there's zero DC.
-63 db is not volume zero Mikkel. I loaded the controller exactly as you say in your instructions, and tried in many other ways, but no way to reach volume zero as normally should be for a volume control.
My question now is: how can we arrange to fix these two problems?
Old 15th December 2009, 12:34 PM   #556
piero7's Avatar
Ron, relays arrived right now
Mikkel, should I change the relays?
Old 15th December 2009, 04:20 PM   #557
Renron's Avatar
Thanks for the updates Piero7
Old 16th December 2009, 02:03 AM   #558
It could be a different problem that's causing the clicks. Piero has no DC, and still get clicks.
The problem is that none of my amps produce this problem, so it's a bit hard to find... I have found a circuit for a 9-pin Aikido, so I will try building that on one of Geek's experimenter boards. I probably won't have time until the weekend.
I do plan to!
Best regards,
Mikkel C. Simonsen
Old 16th December 2009, 02:08 AM   #559
The muting problem could be fixed with a muting relay. But adding an extra relay is not a great idea unless absolutely necessary... One solution if you need a larger range than 63dB could be 1.25dB or 1.5dB steps for a 79 or 95dB range.
The clicks is harder to solve. I'll try building an 8FQ7 Aikido to see if I get clicks also. I don't think different relays will solve the problem.
Best regards,
Mikkel C. Simonsen
Old 16th December 2009, 12:29 PM   #560
piero7's Avatar
Best regards,
Mikkel C. Simonsen
Well, the relays are here, I'll try.
Mikkel I don't care about muting, I want to reach volume zero on first step of the attenuator. There's a way to get that?
Page generated in 2.02055 seconds (5.13% PHP - 94.87% MySQL) with 11 queries
