| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#531 |
Piero7,
I found the floor in my rental house! After moving lots of boxes I found the soldering Iron. Desoldered the 2 resistors in series and measured them to be 96.8K Ohms. I'm gong to order a quality one close to that range. That doesn't help you probably, but how about a picture of your wiring setup. Maybe we can help you trace the problem down. I'm not very experienced with electronics, but I'm willing to help if I can! Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 |
#532 |
I have a configuration made of Control2, Panel2, Inpup1, RelVol1 and I just wonder how to make the mute function available by a front panel button other than from the remote.
In the Control2 manual there is a function called Pin9 HW Mute, but to me it's not clear how to use it. http://www.diyaudio.com/forums/image...s/confused.gif Is there anyboby who already has tried it? Thanks, raffaele |
#533 | |
#534 |
@Renron
I have ordered 6 new relays... |
#535 |
Piero7,
What type are they? I was told (by Mikkel) that it's the relays that actually cause the "click" when changing volume. Did you order the same type or a different brand / manufacturer? I hope it removes the "Clicks"...............I would DEFIANTLY change mine out too! I hate the clicks!!!!!!!!!!!!! Ron
#536 |
I have ordered 6 x Takamisawa RY5W already used in the past and never heard that damned click! 1,5 euro X 1 and if I dont remove the click with these relays I'll dance the tip tap on this fuc@ed board!
For the moment, I'm used the stepper attenuator from Khuzmo |
#537 |
P7,
![]() sounds like a good idea.Please let me know how it turns out! I'd change mine in a heartbeat if it works! Ron
#538 |
Sure
#539 |
Anyone using the Input1 module?
If I leave the CDP playing an change to an unused input I can hear it very faintly if I get up close to the speakers. Its really quiet but I wondered if this was an issue others have noticed? Im using mine in a slightly different way: I have all my RCA grounds tied together. The ground wire connects directly to the volume pot so no input ground connection passes through the Input1 module. I did this to try and avoid any potential ground loops and also to prevent any noise being injected onto the signal ground front the Input1. Maybe I should wire it up in the standard way?
www.drugfreeworld.org |
#540 | |
A lot of posts I haven't seen - I should get here more often
![]() Quote:
If using a RelVol1 or RelVol1C board only, you cannot get full muting. The attenuator cannot attenuate more than 63dB, so you get -63dB when you press the mute button. When you use an input selector also, there is a mute relay on that board. Best regards, Mikkel C. Simonsen |
| Page generated in 0.11555 seconds (81.71% PHP - 18.29% MySQL) with 11 queries |
