Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 650 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 10th June 2017, 02:17 PM   #6491
Originally Posted by Curious Fitz View Post
15v 0 15v 0
9v 0 (using that for the S/PDIF to I2S)Try S/PDIF with transformer input, maybe the s/pdif to i2s is the culprit
I do have other transformers though...?
I get it - use a lower voltage transformer too? Bingo ,
see if the supply get's hot, if so try 12V or even lower depending on voltage drop of supply
I'll get some plastic posts to support the board in the case perhaps: LCBSBM-4-01 ART | LCBSBM-4-01 ART, 6.4mm High Nylon PCB Support for 3.18mm PCB Hole, 12.7 x 12.7mm Base | Richco Looks fine
Also try to keep short (psu & input) cables.
Old 10th June 2017, 02:20 PM   #6492
Please could you explain that a little more?
I am running the S/PDIF board with the transformer input - do you mean use a separate transformer for the S/PDIF board?
Thanks so much for all the advice!
Old 10th June 2017, 02:27 PM   #6493
In the foto i can see an extra board, is that your s/pdif to i2s converter? Maybe this board gives harsh top-end? So try without the board.
See https://hifiduino.wordpress.com/2015...c-users-guide/
For direct s/pdif input with transformer.
Old 10th June 2017, 02:29 PM   #6494
Yes it is - would you recommend using the direct in to the Soekris DAM rather than a separate S/PDIF to I2S then - and why?
Or maybe you mean: try it and see if it is the culprit
Thank you
Old 10th June 2017, 02:31 PM   #6495
Thank you
To make sure the harsh top-end is not coming from this board.
Old 10th June 2017, 02:32 PM   #6496
Brilliant: thank you SO much paulebappie - you are very kind
I really appreciate your help.
I'll report back when I've tried all your great tips
Old 19th June 2017, 12:36 PM   #6497
Well, I've tried now with -9v 0 +9v DC, and, some time to 'burn it in' (40+ hours now) and it sounds truly lovely.
The sound is far smoother than the few hours of play at +-12v DC.
Thank you paulebappie - I am really pleased
BTW I am now designing a case (one for the power supply, one for the DAC) and wondered if there is a pin out for the sync green light that you see on the board, and, what voltage LED I would need to use please?
Many thanks again - I am falling in love with this DAC...
Old 19th June 2017, 12:39 PM   #6498
BTW: I tried adding a tube-buffer amp in-line with the RAW outputs and could hear no difference whatsoever.
Not sure if you need to 'burn-in' tube amps, I guess perhaps so.
I was going to use it to tone down the very harsh 90's electronica CDs ( the ones where they got a bit crazy with all 44KHz available...)
Old 19th June 2017, 01:13 PM   #6499
Good work!
Old 19th June 2017, 02:39 PM   #6500
markusA is offline markusA  Sweden
markusA's Avatar
Soekris> 30min CNC machine time sound awfully high for a front plate in a production run. (Unless it's something extreme we're talking about) I used to do CNC work...
Maybe get a second quote from a competitor?
Current build to be found in my blog. Not so current anymore, everything is put on hold until march.
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright 1999-2017 diyAudio
