Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 381 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 7th October 2015, 02:10 PM   #3801
danny_66's Avatar
Originally Posted by nige2000 View Post
can someone explain how to select filters on firmware 0.99 like i was an infant please
with an example
ive done the firmware upgrade
You have two options:
- Play-mode Command interface
- Setting Command interface (uManager)
See chapter COMMAND INTERFACE @hifiduino
New filters at moredamfilters
My RefSpeaker
Old 7th October 2015, 02:48 PM   #3802
i feel a little stupid unfortunately im aware of these tutorials but i still manage to be clueless
in uManager is it?
example
is it "set filters = 04 bypass FIR1, 384 ksps"
Old 7th October 2015, 03:08 PM   #3803
danny_66's Avatar
In play mode you type: F4 or F5 or F6 or F7 (not the function keys!) for selecting one of the 4 filters
When you go into the uManager (+++) you type:
set filters = Linear
or
set filters = Mixed
or
set filters = Minimum
or
set filters = Soft
Linear, Mixed, Minimum, Soft corresponds to F4, F5, F6, F7
My RefSpeaker
Old 7th October 2015, 03:26 PM   #3804
or
set filters = Mixed
or
or
set filters = Soft
ive The v099 Party Pak downloaded onto the dac
how do I select one of these filters
I appreciate your patience
Old 7th October 2015, 04:27 PM   #3805
danny_66's Avatar
The same.
"set filters = Linear" sets the first of the party pack,
"set filters = Soft" the last.
My RefSpeaker
Old 7th October 2015, 05:19 PM   #3806
zfe is offline zfe
On the use of the uManger and the Fx commands:
Originally Posted by soekris View Post
Maybe a clarification is needed:
Setting configuration parameters in uManager config mode is stored in flash and survive power cycling, should really only be done once.
Using single letter commands in play mode reverse to settings from flash after power cycle.
Really need to get that manual out....
Old 7th October 2015, 06:16 PM   #3807
Set filters = EQHQv5
Old 7th October 2015, 08:01 PM   #3808
danny_66's Avatar
No, if you want the first filter EQHQv5 from the party pack, you enter:
set filters = linear
My RefSpeaker
Old 7th October 2015, 09:59 PM   #3809
ok there's only four options
linear, mixed, minimum, and soft
for each bank of the four banks of filters
would be much simpler if it was bank1,bank2,bank3,bank4
Old 7th October 2015, 10:21 PM   #3810
danny_66's Avatar
Yes, it would be less confusing
With the party pack installed the labeling of the banks isn't anymore correct.
My RefSpeaker
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright 1999-2017 diyAudio
