Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 20 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 30th July 2014, 02:54 PM   #191
soekris is offline soekris  Denmark
Originally Posted by Eldam View Post
Hi Soekris,
What about this question please ?
What ate the electrical outputs data measured at J7
What can be found between the last passive filter cap on the Resistors bench and J7 ?
I try to understand if the oaps can be totally bypassed and/or if the circuit need I/V conversion or gnd after the R2R bench ?
As not a power dac and if the embeded digital attenuation is not totally loss free (ES9018 volume control hint above?), I would like to understand how can be maid the impedance adaptation before an amp if needed (mine e.g. is 100K ohms input)
WHat is the best solution : digital attenuation with a streamer à la SqueezeBox : but here we have the same theorical loss (than O can't here myself with any dac after My squeezeBox when volume control is used in it !) or SOTA ladder resistor pot in an analog pre after the DAC ? If adaptation impedance is not as important with voltage than current, it seems a good ratio for good sound is around 1/10 to 1/20 ... at least this is my simple understanding.
Sorry for the two cents question, I'm not at technician !
The R-2R DAC resistor network is output directly at J7, no parts in between. The output voltage is 1.4V RMS, the output impedance is 1.2 Kohm. The output resistance is also purely resistive, so if heavily loaded the output voltage will just be lower.
So no I/V stage is needed and it's powerful enough to connect directly to a power amplifier....
The DAC volume control is better than any external one, is done precisely in the digital domain with high resolution, and the sign magnitude DAC works the same as the level goes down. T.ex. when volume is at - 72 db it still has 16 bit resolution, just look like there is a -72 db resistive divider after it as the 12 MSB bit resistors's are connected to GND.
Søren
Old 30th July 2014, 03:27 PM   #192
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
Don't know about the rest of yous, but I'm excited about this DAC design. The IV and output stages has always involved a bunch of compromises of some sort in previous DACs I've played with. I'd be regularly thinking of possible tweaks to this or that to get 'better' sound. I never felt it was 'perfect'. Nothing's perfect I guess, but maybe this design could help relieve me from some of the stresses
Then again, how this dac will sound like is still a complete unknown and that can be bit stressful too! Lol
Old 30th July 2014, 03:33 PM   #193
Looks very interesting,,,and it is Danish ::::::
Best Bjarne
Old 30th July 2014, 04:42 PM   #194
HpW is offline HpW  Switzerland
Well, as from the listening experiences (high resolution equipment and using acoustic music): You should drive the DAC with ALL possible bits to get the highest listening resolutions... and afterwords attenuate
while as Soren above declared, you will deal with lower used bits and you will sooner or later
Hp
Download FFT Analyzer & Generator at www.hpw-works.com
Old 31st July 2014, 04:24 AM   #195
On list please for one ,may be two 0.02
Praudio
Old 31st July 2014, 03:06 PM   #196
Myint67 is offline Myint67  Singapore
Up date order
2x 0.02 % or 2x 0.01 pls
Old 31st July 2014, 03:17 PM   #197
Zoran is offline Zoran  Serbia
One + 0.02 for Me...(maybe 2?)
cheers good work
Old 31st July 2014, 04:13 PM   #198
reodds is offline reodds  United States
Søren, have you set up a website for definitive orders, or are you still just getting an idea of how many people are interested fro here?
Can't wait for the actual audio tests!
Old 31st July 2014, 09:22 PM   #199
0.02 for me
Old 31st July 2014, 10:18 PM   #200
Raj1 is offline Raj1  United Kingdom
0.02% = yes. Maybe a few actually for multichannel..
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2017 diyAudio
