Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 191 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 25th February 2015, 06:04 PM   #1901
nautibuoy's Avatar
Default DSD Support
Soren, a question about future DSD support.
Have you designated which J3 header pins will be assigned for incoming DSD data?
I'm working on an interface board that should enable me to use a beaglebone black, running miero's botic software, to feed I2S PCM and DSD data to the Soekris DAC; that means to future proof for DSD capability I need to include switching between I2S PCM and DSD as they emerge on separate beaglebone header pins.
I've assumed (based on other similar implementations);
J3-18 (I2S BCKL IN) = DSD BCKL
J3-20 (I2S LRCK IN) = DSD DATA 1
J3-22 (I2S DAT IN) = DSD DATA 2
Are you able to confirm?
Ray
Old 25th February 2015, 08:06 PM   #1902
soekris is offline soekris  Denmark
Ray
My plan is to do DoP, then no special hardware connections is needed as the DSD data is encapsulated in a PCM stream, being sent over USB or SPDIF.....
Søren
Old 25th February 2015, 08:14 PM   #1903
Hi Soekris, how do you think of my Pure DSD decoding concept for DAM? Have been asking your several times with no response... Than kyou
Sent from my iPhone using Tapatalk
Old 25th February 2015, 08:26 PM   #1904
Not gonna work, you still need filtering at 50-70 Khz and you also need to support DSD128.... My plans are the simple way, probably like everybody else, convert to PCM at 352 Khz, then filter, volume control and output....
Søren
Old 26th February 2015, 06:49 AM   #1905
nautibuoy's Avatar
So the DAC doesn't support native DSD. Not a problem if it is known about and, as you say, what a lot of others do.
My understanding is a bit limited in this area, so seeking to understand better. I believe most of the USB input devices (and network renderers like the Edel) likely to be used with the DAC (Amanero, Wave, etc.) present PCM output as I2S and, if supported, route DSD output over the same shared header pins? Assuming these devices can accept a DoP format data stream on their input, by implication they must process the data so the DAC won't see DoP via this route?
Old 26th February 2015, 07:30 AM   #1906
Any news on whether we can expect a fix for plops and cut-outs on Fs change?
Old 26th February 2015, 11:27 PM   #1907
Question for Soren and others that know power supplies better than I...
I'm working on an initial implementation of my Soekris DAC in a setup where in addition to the +- supplies I need for an off-board output stage, I have 2 completely separate supplies currently configured as +11.5v each. When I say completely separate, they have separate transformers and only get a ground reference when they are connected to the powered circuit.
I could of course reconfigure one of these to a negative supply, rewiring the transformer outputs to the other side of the diodes and connecting them to the - terminal on the filter cap.
And I also believe I could just connect the wire from the - terminal on the filter cap of that supply to the - supply input and the wire from the + terminal on the filter cap to the + supply input on the Soekris DAC. And VOILA!, it is now a negative supply!
If I do this, then I don't need to rewire the supply and can more quickly, easily, and with less opportunity for making expensive mistakes change back and forth between the current DAC card in that setup (which uses two positive supplies) and the Soekris DAC (which needs both a positive and negative supply).
And of course, once I get the Soekris DAC settled (trying various powering and output stage options, plus updating the firmware and filters), I will rewire that supply into a negative one.
And I should add that I will have high-quality (modified Dexa) + & - 9v regulators at the + & - inputs to the Soekris DAC, so I won't be feeding it un-regulated 11.5v.
First, would that work ok?
Second, what are the drawbacks to doing this?
THANKS!
Greg in Mississippi
Everything matters!
Old 26th February 2015, 11:36 PM   #1908
I'd settle for a manual at this point....
Old 27th February 2015, 01:30 PM   #1909
Soren,
I have been testing input switching with INP_SLCT0 and INP_SLCT1 lines and have noticed some problems.
I used the connection information you posted in #901:
Input Select is:__INP SLCT0___INP SLCT1
Auto_____________N-C_______N-C
I2S______________GND______GND
SPDIF1 (Coax)_____N-C_______GND_____(Sensitive LVDS receiver)
SPDIF2 (Toslink)___GND_______N-C______(Standard 3.3V digital level)
If you don't connect anything to the input select pins it will search the three inputs for a valid signal and lock when found.
I have tested the actual voltages on J3 pins and they are 0V for GND connection and pulled up to 3.3V for N-C.
In Auto mode (both lines not connected) it works as expected, locking onto the first input that has signal. Turning on signal on other inputs after that does not change the input selection.
In I2S setting (both lines to GND) the DAC works as expected. It locks onto I2S signal if present, and does not lock on anything if I2S is missing, but SPDIF signals are present.
In SPDIF1 (Coax) setting (SLCT0 N-C, SLCT1 GND): If the dac was previously locked to I2S input, it will stay locked to I2S even if SPDIF signal is present. If the DAC had not locked on I2S before switching to this selection, it will lock on either of SPDIF inputs - not just COAX, but also TOSLINK if signal is present there.
In SPDIF2 (Toslink) setting (SLCT0 GND, SLCT1 N-C): If the dac was previously locked to I2S input, it will stay locked to I2S even if SPDIF signal is present. If the DAC had not locked on I2S before switching to this selection, it will NOT lock neither on TOSLINK nor COAX inputs.
Can anyone confirm this behaviour? Could these be firmware issues?
There is also a problem with PWRLED output (or I have not connected it correctly). I connected it to a LED through resistor to GND. Is that the correct connection of PWRLED pin?
With this connection PWRLED works in reverse to the onboard LED. When the onboard LED is on, PWRLED is off. When the onboard LED is blinking, PWRLED line blinks in reverse.
There is another small thing - if the volume pot is not connected during dac power-on, the volume will be set to 0dB. However, if the volume pot is disconnected while the dac is powered on, the volume goes to maximum +6 dB. It would be nicer if it went to 0dB level, although this is of course a lowest priority isssue.
Old 27th February 2015, 04:00 PM   #1910
reodds is offline reodds  United States
Kuribo, Søren has not been feeling well and has stated that he will be working on the manual this coming weekend. Patience...
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright ©1999-2017 diyAudio
