Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 174 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 14th February 2015, 09:01 AM   #1731
TNT is offline TNT  Sweden
Great, thanks! The rePhase file will be handy!
Old 14th February 2015, 09:06 AM   #1732
Originally Posted by ylingf View Post
I am pretty puzzled here. I was able to update the firmware and upload the filter that Paul generated, all looked fine. But now when I try to connect again, the uManager is not coming up after +++. I can still see some characters when DAC power up, but whatever I type is not taking effect. I have tried three different USB to serial adapters and two different PCs, same result. Any clue?
Have you tried selecting Flow control: None (DTR/RTS) ENABLE ?
Old 14th February 2015, 09:11 AM   #1733
Originally Posted by SebastianL View Post
You're not the only one
My experiance is that I got it working with Zterm on OS X but missed the macbinary setitng so update failed. This made me resort to my backup PC laptop and that worked. Trying to used Zterm again I just cant seem to get that working anymore. Strange. I'm dam-ed if the DAM dont change some setting / states after it has been used wich seem to stick. Something fishy is going on I suspect.
Old 14th February 2015, 10:01 AM   #1734
Aha...
Fiddled around with zTerm settings and voila.. worked (excuse me for attacking DAM Sören).
I happend to send "release call" and 8-o :
dam1021 uManager Rev 0.80 20150121 FPGA Rev 0.9 Press ? for help.
# ATH0
Invalid Command.
# help
uManager Commands
I have a 3 meter extension cable with a USB/serial dongle:
Product ID: 0x6001
Vendor ID: 0x0403 (Future Technology Devices International Limited)
Version: 4.00
Serial Number: FTDXFFMH
Speed: Up to 12 Mb/sec
Manufacturer: FTDI
Location ID: 0x14200000 / 7
Current Available (mA): 500
Current Required (mA): 44
Zterm settings where:
- No Xon/Xoff
When a do exit in umanager it says:
# exit
I2
L044
V-22
and +++ gives (no local echo)
As it should be. Seems to be some initialization problem with something.
Old 14th February 2015, 11:23 AM   #1735
But alas, i could not repeat it... hmmm
So no easy contact again...
Old 14th February 2015, 12:36 PM   #1736
The rumour has spread to the head-fi community.
Old 14th February 2015, 12:38 PM   #1737
Yes, kind of fishy or spooky even. Now you see, now you don't.
Old 14th February 2015, 12:51 PM   #1738
leehan is offline leehan  United Kingdom
Seriously, on Mac, give Serial app a try: https://www.decisivetactics.com/products/serial/
I had the same ZTerm issues, not being able to connect again. Serial worked every time. I'm at the end of 7 day trial but will buy the license. It also comes bundled with drivers for various USB serial converters, which may be convenient for the particular converter you are using.
Old 14th February 2015, 01:04 PM   #1739
ylingf is offline ylingf  United States
I let the board powered off overnight, first try in the morning, now works just fine. So weird.
Old 14th February 2015, 01:05 PM   #1740
zfe is online now zfe
When I had similar problems (using screen, not Zterm), unpluging the Adapter (USB side) looking for old, detached screen-processes and killing them (with activity mointor) and/or ultimately un- and repower the DAM usually helped.
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2017 diyAudio
