Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 134 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 5th February 2015, 10:22 PM   #1331
soekris is offline soekris  Denmark
Originally Posted by Sandor View Post
Hi Soekris,
I have received the DAC board. The box did not contain any instructions.
Is there a manual other than the schematic of the board posted on this thread?
I wonder whether the installed firmware is version 0.8 or 09. How can I check the version of the installed firmware?
Until the manual is ready, there is great info here: https://hifiduino.wordpress.com/2015...kris-r-2r-dac/
All shipping products so far have rev 0.8 firmware.
Søren
Old 5th February 2015, 10:28 PM   #1332
Originally Posted by acko View Post
Aside from this 44.1k 80s technology.... If your DAC is fed with a natively recorded super Hi-res material like DxD (352.8) would it make sense to bypass all these up sampling processes/filtering and operate in true NOS mode?
If feed 352K/384K then the FIR1 filter is bypassed. I have the opinion that FIR2 is best to keep on, it's a short one operating at high sample rates.
But when I release the filter tools and docs, there will be instructions how to bypass that one too....
Søren
Old 5th February 2015, 10:37 PM   #1333
Talking about filters.... The really critical ones are the 44.1K and 48K ones. I have been researching a little on the net, and found out:
HQPlayer seems to be the reference and their best filters is what they calls "Poly-Sinc" filters, but I don't seems to be able to find any info what they are exactly.... Anybody know something ?
There is something called "Windowed Sinc" filters, have found some references and t.ex. the ScopeFIR package can generate them.
Anybody knows of other tools that can generate them, preferable no or low cost ?
Any other ideas to what the best filters actually are ?
Søren
Old 5th February 2015, 10:46 PM   #1334
acko is offline acko  Australia
Thanks Soren, this is excellent!
Personally, I have this fuzzy feeling about upsampled music, you know trying to fill in missing bits with nulls or approximations and then trying clean out with elaborate filtering that will only color the sound whatever the technology. -I think
So it is interesting to see how this DAC performs with with DxD selections notably
from 2l -Nordic
AckoDAC Project
Old 5th February 2015, 10:48 PM   #1335
I have a feeling this dac will turn out to be like fine wine. Right now it has just been bottled and tastes a little rough. It's potential is evident though. Time is needed for its full potential to be realised. I think the filters will be one of the key elements. They seem to be just place holders at present until the options are better understood. Soekris might like to collaborate with someone who can really contribute in this area in an open source way...
Old 5th February 2015, 11:06 PM   #1336
I am sure it will be. My own expectation, if it can outperform the 9018 DAC, I for one would change my position from sell to buy (or resell)
AckoDAC Project
Old 5th February 2015, 11:32 PM   #1337
All the experts here, is it possible to just run this DAM1021 as a pure 1 bit 2.844mhz pure DSD dac? Just combine all 28bit as one bit and program the Dac to do 1bit mode. Also the pcm value can be used as a perfect volume control. Thank you
Sent from my iPhone using Tapatalk
Old 6th February 2015, 12:00 AM   #1338
Originally Posted by hop.sing View Post
I got my dam1021 DA in the mail today
Which version? It would be helpful if everyone giving subjective impressions mentioned which version they are using
Old 6th February 2015, 01:39 AM   #1339
casshan is offline casshan  Hong Kong
Hi Soekris,
I just got 9 pieces R2R DAC, thanks a lot!
I'd like to install the dac into my network player, replace the original dac. Does the R2R dac support I2S signal for CS4398?
Old 6th February 2015, 02:44 AM   #1340
Originally Posted by casshan View Post
Hi Soekris,
I2S is I2S. You have three connections, plus 3.3V power and gnd.
SCLK -> BCLK
LRCK -> LRCLK
SDIN -> DAT
You'll have to workout where to pick up 3.3V and GND to power the isolators.
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright ©1999-2017 diyAudio
