Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 103 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 26th January 2015, 06:29 PM   #1021
soekris is offline soekris  Denmark
Originally Posted by MisterRogers View Post
Soren - when do you expect your shipment for USA distribution will land in the states?
Just got confirmed that boards did land at the US office, and I expect that most, if not all, orders there will be shipped out today.
And just to say it again, I do engineering and manufacturing, the two online stores do the actual order processing and shipping so I can't answer for them. Any questions related to individual orders need to be directly to one of the two online stores.
Søren
Old 26th January 2015, 06:34 PM   #1022
Originally Posted by soekris View Post
Everything need a GND reference, a voltage is always referenced between two lines....
Just to clarify, to power the onboard isolators the Amanero +3.3V connects to ISO +3.3V and Amanero GND connects to ISO GND? (or non ISO GND?)
Old 26th January 2015, 06:48 PM   #1023
Anything to be isolated connects to the pins inside the box saying "isolated".
If you mix it you break the isolation and/or it won't work.
Søren
Old 26th January 2015, 06:49 PM   #1024
ristar is offline ristar  Singapore
Depends on your grounding scheme of choice, really (whether you want to isolate this etc)...? In general, the GND is the reference point... for which the +3.3V is needed. If you take GND reference from some place else, the +3.3V may end up reading a different value and that will cause problems... or worse, potentially cause damage.
Old 26th January 2015, 09:13 PM   #1025
I'm happy to confirm that I have beautiful music playing out of my SBT->Amanero->DAM-1021-01 bal. out->Questyle CMA800R->LCD3
at first try
Old 26th January 2015, 09:15 PM   #1026
Please share some first impressions when you're ready. Of course, it needs a proper burn in, but, first impressions are still welcome.
Old 26th January 2015, 09:22 PM   #1027
Will do.
I got short initial bleeps and blops when changing songs w. diff. sample rates just like TNT had.
Apart from that nothing wrong. LED is on steady.
Old 26th January 2015, 10:15 PM   #1028
supra is offline supra  Australia
at first try
Can you post close up photo of your connections, quite a few of us will be using amanero.
Old 26th January 2015, 10:17 PM   #1029
TNT is offline TNT  Sweden
Compared running 7VA batteries against my two Mean Well RS-15-15 15 Volt 15W. Maaaybe a slight difference. But not all + for the batteries. So very good power system for DC onboard this DAC. This makes mer just more sure that you dont want to hook up a trafo because this will cause rectifying switch residulas from the mains freq + all the overtones. I will not even try it as it must be the least optimal solution.
And before you cram it into an aluminum box, play it freely on nylon standoffs. I put a bit of sorbothane on the oscillator I laways dampen my oscs.
So anyways. This DAC has at least 3 very good qualities. Dynamics is one. A big deep open stage is an other. A third is that it rest on a real solid fundamnet bass wise. I'm thinking about some others... Isn't there anythig to pick on? Maybe...
Old 26th January 2015, 10:49 PM   #1030
I had the same thoughts. I guess I'll rig up a simple +/- 12VDC to power this with. Or, maybe I go overboard and use a Salas Shunt?
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2017 diyAudio
