Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 102 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 26th January 2015, 03:01 PM   #1011
it would be nice to finally have some sound impressions comparative to other well known DACs and their implementations such as the TDA1541, PCM1702, CS4398, ES9023, ES9018, pcm5102, etc. ; I would be curios about a particular sound signature of this R2-R DAC compared to these other DACS from those who own or have listened to some of them
== There are no limitations to the self except those you believe in ==
Old 26th January 2015, 03:06 PM   #1012
I am sure it will come
BTW: A really nice looking pcb with alot of very small parts arrived safe and sound at home today
Old 26th January 2015, 03:12 PM   #1013
Can you say Audio?
Soren - when do you expect your shipment for USA distribution will land in the states?
Old 26th January 2015, 03:29 PM   #1014
alecm is offline alecm  Ukraine
Soekris,
please find out what is going on with my order. I have paid Wednesday. But till now i haven't any reaction on my order and numerous letters to you and company. Thank you in advance.
Old 26th January 2015, 04:13 PM   #1015
Originally Posted by alecm View Post
Soekris,
Speaking for Soekris, he doesn't handle the actual orders, he has someone who takes care of that part of the business.
And many people put in their orders ahead of you, so I imagine you need to relax a little, and wait.
If you were not in the first group (I put my interest in last summer BTW), then you will have to wait for the 2nd batch of boards, 1st batch is sold out. This info is in the first post.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 26th January 2015, 04:39 PM   #1016
ristar is offline ristar  Singapore
This is his update with regard to those who ordered from the US store:
Post #885
Old 26th January 2015, 04:54 PM   #1017
Stixx is offline Stixx  Germany
Stixx's Avatar
Sadly I have seen this over and over on Diyaudio when a new offer came out... people being all over the place and complaining, writing numerous(!) letters but not being able to just read a few pages of the thread and finding the important bits. It's not like you are shopping at Amazon, Mr.!
www.original-ton.net
Old 26th January 2015, 05:14 PM   #1018
TNT is offline TNT  Sweden
Originally Posted by soekris View Post
In principle any source should output zeroes when it don't have valid audio, if you need a "mute" pin then the source (read amanero) have a problem....
On the other hand the R-2R DAC shouldn't output anything without valid input data.... I'm currently muting by uC firmware, but that only check the input every 100 mS. There are supposed to be real time muting in the FPGA, but I had trouble with it, and as I otherwise didn't experience any problems with my setup (using a DIYINHK usb interface), I decided to complete that part later....
There is no direct mute input to the R-2R DAC, I just need to work on completing the FPGA mute circuit...
Okidoki. Just so you know - volume setting has no impact on blog level.
Old 26th January 2015, 05:21 PM   #1019
Originally Posted by TNT View Post
If you look at the drawing Sören provided of the board, there is a box surrounding the inputs/outputs that is "isolated". None of these are used for galvanic or opto s/pdif.
- Galvanic s/pdif (shoild) use a transformer which is passive alas, no power needed.
- Opto requires a receiver module which is active and needs power - however as the glassfibre cable isolates the dad for outside, no isolation on-board is needed and this, the device can be seen to belong to the core DAC itself (the isolated part) so power should be taken from S2 but from pins outside the ISO box as these provide power (the ISO power must be fed power)
I only have USB possibilities.
Let me correct som spelling erros in this post. Forgive me my sloppy writing. It is affiliated with my weakening eyesight
- Opto requires a receiver module which is active and needs power - however as the glassfibre cable isolates the DAC from outside, no isolation on-board is needed and thus, the device can be seen to belong to the core DAC itself (the isolated part) so power should NOT be taken from S2 but from pins outside the ISO box pins as these provide power whereas the ISO power pins must be fed power)
Old 26th January 2015, 05:24 PM   #1020
Can you say Audio?
Thanks mate - as it's the 'Monday' referred to in #885 (I think), was curious where board arrived in the US, and are still scheduled to start shipping today.
Not riled up mind you, just curious.
I have transformers inbound, along with the parts needed to complete the power supplies. Really looking forward to checking it out.
Post #885
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright ©1999-2017 diyAudio
