Pulsar Clock - Ultra Low Noise OCXO - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 23rd November 2016, 06:14 AM   #61
Went just now to www.pulsarclock.com and saw something about 35% discount on orders between 25-27 November 2016.
I'll bite..
LH/S
Old 23rd November 2016, 07:10 AM   #62
Sorry, my mistake... 35Eu and not 35% - and that's a massive difference.
Apologies.
LH/S
Old 22nd December 2016, 11:06 PM   #63
Pulsar Clock's Avatar
Default Season's Greetings
Season's Greetings and Happy New Year from the Pulsar Team
www.pulsarclock.com
Let its heart beat for your music
Old 23rd December 2016, 05:19 PM   #64
clsidxxl's Avatar
Thank Pulsar team,i wish you a prosperous year
Old 10th January 2017, 02:30 PM   #65
Poseidon's Voice
Dear Pulsar team,
Any application for your clock in these 2 circuits?:
The ο1 precision master clock
The γ24 high performance DAC core
Thanks! They both use the Crystek CCHD-957 with the ADM7150 (3.3V) regulator.
Best,
Anand.
Old 11th January 2017, 07:25 PM   #66
Originally Posted by nycavsr2000 View Post
Dear Pulsar team,
There's no way to install two Pulsar Clock on the Omicron precision Master Clock.
The problem is electrical: the Pulsar Clock doesn't have a three-state output (i.e. an enable/disable capability on pin1) so it is impossible to connect two Pulsar Clock output lines the way it is implemented on Omicron 1.
www.pulsarclock.com
Old 11th January 2017, 07:26 PM   #67
Dear Pulsar team,
The Gamma24 board appears to be adequate to support the Pulsar Clock.
To install the Pulsar Clock you have at least two choices:
OPTION A:
- remove the SMD clock on the Gamma24 board and build a sort of pilework to support a small board with a DIL14 socket for Pulsar Clock.
- have great care to verify the Pulsar Clock Vcc and GND connections before to power up! An inversion of the polarity burns the Pulsar Clock and it can't be repaired.
Connect Pin 7 on Pulsar Clock to Pad 2 on the Board (GND)
Connect Pin 8 on Pulsar Clock to Pad 3 on the Board (Out)
Connect Pin 14 on Pulsar Clock to Pad 4 on the Board (Vcc)
Do not connect electrically the Pin 1 of Pulsar Clock, you can use it as a mechanical fastening
Pros:
- minimum Jitter introduced by the modding, most likely insignificant.
- return current from the clock goes through the path forseen by the board designers with minimum EMI impact.
- standard 1/10" (2.54mm) parts could be used for the modding.
Cons:
- medium complexity modding, requires some expertise to remove the SMD clock that most likely won't be reusable with its maximum performance unless removed with adequate rework tools.
- a minimum of soldering experience is required to solder the pilework to the board not damaging the nearby components and the board itself
OPTION B:
- leave the SMD clock in place
- install the Pulsar Clock on a board aside but located as near as possible to the Gamma24 board, preferably using the provided Pulsar Clock socket.
- connect the three Pulsar Clock pins Vcc, GND and Out to the three points shown in the following picture. The ADM7150 should have no problem to provide power to the two clocks. We suggest to connect Vcc upstream L1 in order to have a minimum separation between the two clock power supply.
- do not solder the output wire to the Pin2 on J1, use instead a single socket connector from a 1/10" (2.54mm) row in case you want to restore the original clock.
Pros:
- easy modding, minimum expertise is required
- SMD clock remains in place and the original configuration can be restored if desired
Cons:
- some Jitter could be introduced on the output connection due to the usage of a wire. If a coaxial cable is used be sure it is an high frequency cable and DO NOT connect the shield to ground to both sides otherwise you create ground loops introducing Jitter, if you want to use a coax connect the shield to ground only at Pulsar Clock side.
- Power Supply return current have an optimum path on pin 25 of the Gamma24 board but it is not the path forseen by the board designers so some jitter could be induced on the Pulsar Clock output.
- both clocks share the same power supply running at the same time at a very very near frequency with possible interference and unpredictable Jitter effects. Often two clocks run in many systems with a unique power supply and this appears not to be a problem but is better to take it into account.
- please, note that these cons are general warnings given to obtain an optimum result but also the option B can give very satisfactory results.
www.pulsarclock.com
Old 12th January 2017, 07:06 PM   #68
Poseidon's Voice
Pulsar,
I discussed this at the AMB forum and the designer of the Omicron 1 board replied with this:
On most standard CMOS oscillators there is an enable/disable pin (usually pin 1). This applies to the Crystek CCHD-957. It can be left floating (i.e., not connected), and an internal pull-up resistor will enable the oscillator. When the oscillator is disabled by feeding logic "low" to the enable/disable pin, the oscillator output becomes disconnected from the rest of the circuit so as not to "fight" another oscillator that is enabled.
On the γ24, this pin is not used. Thus the oscillator is always enabled.
On the ο1, the pin is used to select between the two oscillators in dual-frequency configuration (enable one but disable the other, or vice versa) via the SEL input. But in single-frequency configuration, this pin is unused and X1 is always enabled.
So it should be possible to use a pulsar clock on the ο1 when configured for single frequency only
So it should be possible to use it with the Omicron 1. Please discuss.
Thanks,
Anand.
Old 12th January 2017, 08:03 PM   #69
The reply of the Omicron 1 board designer is absolutely correct.
I didn't see any reason to install a single clock on the o1 so my answer was referred to the dual clock configuration.
If you need to run only one clock the Omicron 1 works fine with a Pulsar Clock and you can place it both in the X1 or the X2 position as it appears more convenient, you just need some fine modding to fit the different pin patterns.
www.pulsarclock.com
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 21 6th July 2014 10:39 PM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 07:01 AM
TI LMK03806 Ultra-Low Jitter Clock Generator mr_push_pull Digital Source 0 18th December 2011 05:33 PM
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 02:03 PM
OCXO 16.9344MHz LOW JITTER CLOCK szjyec Digital Source 23 11th October 2010 03:23 PM
Copyright 1999-2017 diyAudio
