Amplifiers by Analog Audio Labs - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 7th June 2014, 01:34 PM   #1
Default Amplifiers by Analog Audio Labs
This beautiful power amp available @ analogaudiolabs singapore
Selling price : SGD 3800/-
Call now +65 83195040
Product Description
Dared DV-845 MONOBLOCK POWER AMPLIFIER (SINGLE-END CLASS A)
TECHNICAL SPECIFICATIONS:
DV-845
MAX OUTPUT POWER: 36W
FREQUENCY RESPONSE: 20-20KHz (0.8dB)
DISTORTION: 1%
SIGNAL TO NOISE RATIO: 89dB
INPUT SENSITIVITY: 870mV
INPUT IMPEDANCE: 100K ohm
OUTPUT IMPEDANCE: 4 ohm/8 ohm
SIZE: L495 x W260 x H180 MM /piece
WEIGHT: 50.0Kg/pair
TUBES: 845 x 2, 6SN7 x 4
Old 8th June 2014, 12:55 AM   #2
Default WTS:Vp-99 DARED Tube integrated amp 50W (KT88)
This is a new design from DARED. Now available at AnalogAudioLabs singapore
Analog Audio Labs Singapore ! Tube amplifiers, Dealer for DARED tube-amps | Valve-tube hifi | High-end audio system
A nice integrated amp with 50W per channel.
Another feature is that it comes with a subwoofer out, for those who want to connect an active sub to the system.
It is well designed and strongly built.
Priced at SGD 1450/-
Some specs:
Model : VP-99P
Power output : 50W per channel
Tubes : KT88 x 4, 12AX7 x 5
Input sensitivity : 210mV
Size : 49.5cm x 23cm x 22cm (W x D x H)
Weight : 25 Kg
Call +65 83195040 for an audition today
More details here:
Click here for VP-99P details
Old 8th June 2014, 05:29 AM   #3
Default WTS: 845 Power amp + MC-7P pre amp (combo price ) grab it !!!
This beautiful amps available @ ANALOGAUDIOLABS singapore
Call / msg /whtsapp +65 83195040
Brand New Dared VP-845 amp, sealed in original factory box
Now going VP845 power amp + MC-7P preamp @ combo price @ SGD 3300/- dont miss this chance to have a very good amp at the stock clear price.
DARED VP-845 , the BIG tube amp!
6moons reveiw
6moons audioreviews: Dared VP-845
Visit our site for more info :
MC-7P
The tube covers (shielders) are coated with 18K gold (since all signal tubes are shielded, the preamp is very quiet -- one of the quietest MM phono preamps). Tube socket and PCB are planted with 18K gold too (no oxide issue here, best contact and connection). All signal wires are pure silver. The circuit design is very complex (Three tubes are used in power supply section in the circuit), Dared engineers and audiophiles worked together to collect best designs available and optimized this one with state-art technologies by computer programs. Here is, you simply cannot get better one with this price, period.
Some reviews here: 6 Moons Review
Specifications
Frequency response: 10 Hz to 30 kHz
Signal to noise ratio: 93 dB
Signal to noise ratio(MM): 75 dB
MM gain: 39 dB
Tubes: 12AX7 X 4 nos, 12AT7 X 1 no, 6P6P X 1 no, 5Z3P X 1 no
Size: 34 cm X 29 cm X 16 cm
Weight: 12 Kg
It uses 7 tubes and has two huge separate (yes separate--- only Dared design this way. Simply the best) power transformers: one for high DC volt and one for low volt of tube heaters and others. The capacitors use Audiophile grade and the key resistors use NOS AB and Vishay non-inductive. The tubes come with the amp are Chinese stock Ruby tubes.
Old 14th June 2014, 01:44 AM   #4
Default Dared MP5 Tube amp
This beautiful amp available @ ANALOGAUDIOLABS sinigapore
MP-5 price.... SGD 500/-
:-X
Call /Msg/ Whatsapp +6583195040
Visit www.AnalogAudioLabs.com for more information.
A stylish tube hybrid amp
Tube pre with MOSFET output with per channel
Built-in USB DAC
Attractive glossy piano finish
Specifications
18 W per channel
Input sensitivity: 250 mV
Inputs: AUX, USB
Tubes: 12AX7 X 2 nos, 6NE2 X 1 no
Weight: 5 Kg
Old 14th June 2014, 01:48 AM   #5
Default MC-7P Dared Pre amp with remote and phono input
This excellent pre-amp is available at analogaudiolabs singapore
MC-7P
[b]Now going for SGD 1200/-.
Specifications
MM gain: 39 dB
Weight: 12 Kg
Call/ Msg / Whatsapp +6583195040 if interested
Visit Analog Audio Labs Singapore ! Tube amplifiers, Dealer for DARED tube-amps | Valve-tube hifi | High-end audio system for more models
Old 14th June 2014, 01:53 AM   #6
wintermute's Avatar
Analogaudiolabs I have merged your vendors bazaar threads (and given a generic title). Please see the rules regarding posts to vendors bazaar. Vendors Bazaar Rules
If you wish to have multiple vendors threads you can consider purchasing a vendors forum over which you have control.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 28th June 2014, 01:46 PM   #7
Default MP-15 (KT88) DARED integrated tube amp
Now the DARED MP-15 is available with KT 88 tubes.
The most value-for-money SET amplifier in SG market.
priced at SGD 980/-
This beautiful amp available @ analogaudiolabs singapore
Call /Whatsapp +65 83195040.
Amplifier details here : MP-15
Excellent design
Single ended tube integrated
Unique stainless steel and piano black finish
KT-88 tubes can be replaced with 6550 to make it more musical
An all rounder with warm sound and moderately fast enough for modern music trends
Specifications
18 W per channel
Input sensitivity: 300 mV
Output impedance: 4 ohms, 8o hms
Tubes: KT88 X 2 nos, 12AX7 X 2 nos
Weight: 15.5 Kg
Old 8th July 2014, 12:34 PM   #8
Default Melody Tube DAC from Analogaudiolabs (24Bit 192KHz)
Introduction Sale of Analogaudiolabs Brand Tube DAC
Model : Melody DAC-1 (24Bit 192KHz)
The most value-for-money, brand new DAC in SG market.
priced at SGD 530/- ( only for introduction sale). Nobody can beat this price for this spec...
Grab this set before finish the introduction sale .....
This beautiful DAC available @ analogaudiolabs singapore
So hurry for a no-obligation audition this week. Call / Msg / Whatsapp @ +65 83195040.
Description
1.Genuine imported processing chip, CS8416 for Digital Receiving part and pcm1794 as decoding part, plus OPA2604 for op-amps.
2.Produced elaborate Main Amplifier Boad adopt "Double-Sided Board" design.
3.All resistors and capacitors are audiophile grade to ensure sound quality, such as Germany WIMA capcitors, American DALE resistors.
4.R-shape high efficiency transformer. Gold coated RCA connectors and coaxial connector.
5.Brushed aluminum (6mm thickness) faceplate,with all metal buttons and knobs, plus blue LED indicator light.
6. Separate power supply rectification to analog and digital circuits.
7.When there is no signal input, it'll become mute automatically.
8.Control part adopts MCU for the implementation of functional control of every part, and all the channel state and volume state are memorized at power-off moment.
Would like to Buy Pass Labs Amplifiers bassfeen Pass Labs 41 22nd December 2013 01:39 PM
Looking for analog audio circuit designers and audio researchers cnotley Everything Else 1 29th September 2008 10:04 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 09:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
