AudioPower DPS-500-DA in GB - Page 15 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th May 2014, 03:44 PM   #141
Stefany is offline Stefany  Italy
Banned
Ooops! I hope a moderator can help me by deleting a copy. I apologize.
Old 15th May 2014, 06:03 PM   #142
Eric06 is offline Eric06  France
Hi, optionally you could self edit the duplicated post and remove its contents.
If I may, the new model raise questions
- is the DPS-500/UR due to replace DPS-500S ?
- if one want to choose betwen the 2 PSU models by comparing those, then what would be the respective advantages/disadvantages for each?
Old 15th May 2014, 07:39 PM   #143
Banned
Really? but I see no edit pushbutton.
Primary differences between / S - / UR
The "S" version, is fully regulated by the owner synchronized analog power regulator stages, with dual feedback, and offers top performance as noise, and speed of response. if used in audio power amplifier is also capable of maintaining the voltage perfectly balanced between the two rail vcc, during the current demands, we know well be unbalanced. this is an additional benefit for an audio amplifier.
The "UR" is like an unregulated smps but with two new features that go well in the case of audio amplifiers.
1) the output voltage is independent of the ac line voltage, so we can adjust 62V for example, and see that they are very stable.
2) the output voltage is dependent from the current request, (as in the case of traditional unregulate smps), but with a percentage of fast regulation. we have set this value to about 30%.
So we have:
A smps very clean (this also uses a feedback loop) as opposed to a traditional unregulated.
A high ratio of power / size / heat
A well-fixed output voltage.
For me. Said the pros and cons, it is not easy,maybe is "condition" dependant. I think this version can be well accepted, in place of a large toroidal with big caps.
Out doubt, the "S" version, is "for us" in terms of measurements, we can not imagine better.
Stefania
Old 15th May 2014, 09:31 PM   #144
Thanks a lot for your clear answers about the differences between the 2 PSUs.
I guess you are right for the present case perhaps for one of the following reasons though I don't know which one is at stake:
If you have registered, you will be able to edit and delete your posts. Note that the administrator can disable this ability as he desires. Your ability to edit your posts may also be time-limited, depending on how the administrator has set up the forum (source: FAQ about Edit).
Edit: I could edit this post immediately after so perhaps it is just time limited on this thread.
Last edited by Eric06; 15th May 2014 at 09:35 PM. Reason: Edit button seems to work for this post.
Old 25th May 2014, 02:45 PM   #145
pinnocchio's Avatar
did some of you received their DPS-500 and tested the FO?
Ciao!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 25th May 2014, 02:50 PM   #146
Catal is offline Catal  Italy
Not till now.
FO is waiting for the right juice ...
Frank
Old 4th June 2014, 06:27 PM   #147
AudioPower modules just received.
Here you have some pictures.
Old 4th June 2014, 06:36 PM   #148
Pictures?
Old 4th June 2014, 08:18 PM   #149
danny_66's Avatar
Looking nice
Looking forward to mine, they just left Rome according to UPS.
My RefSpeaker
Old 7th June 2014, 08:57 PM   #150
danny_66's Avatar
They have arrived and already found a comfy place in the case :-)
My RefSpeaker
FS: The Wire LME49830 with Audiopower DPS-600 power supply crazikid Swap Meet 17 13th May 2014 10:01 AM
DPS-500/D & CD254 giannettino Class D 13 9th August 2013 04:41 PM
HYPEX NCORE NC400 and AUDIOPOWER DPS-500/S Power supply atoluma Swap Meet 5 15th February 2013 09:24 AM
DPS-500 Innovative Power supply for Audio AP2 Class D 17 19th November 2010 01:37 PM
Denon DA-500 Tubed DAC clocking DutchMark Digital Source 15 8th December 2006 12:41 PM
Copyright 1999-2017 diyAudio
