SMPS 1200A,how to hook it up
Hi ,don`t know how to hook it up really ,there is no Plan with it for Pin Out.Just fit everything in a new housing with better Heatsinks and one SMPS first,but enough Place to put a second one in.
Hi Andrej,
Is it to late to include me on your list for 2 DC sense?
No, never too late hehe
You're on the list now. Just preparing proformas for DC sense, expect it in an hour, 😉
Hi Dirk
SMPS1200A400 datasheet with connection diagram you can find here.
DC sense is connected to shutdown function pins - connector J4: pin 9 (-), pin 10 (+)
Connection sch will be published here before anyone will receive DC sense, so no worries at all.
Regards L.C.
DC Sense kit GB
danny_66 4 DC sense kit
Theodosis O. 2 DC Sense kit
Brianco 2 DC Sense kit
quan 4 DC Sense kit
flyboi 4 DC Sense kit
ZZoran 4 DC Sense kit
giannettino 2 DC Sense kit
Pinnocchio 2 DC Sense kit
Catal 6 DC Sense kit
Rick G. 2 DC Sense kit
Eric06 2 DC Sense kit
Audionootje 4 DC Sense kit
BYRTT 4 DC Sence kit
Dmitry Nevozhay 2 DC Sense kit
kimon 2 DC Sense kit
fredlock 2 DC Sense kit
loek 2 DC Sense kit
Sum of 50 DC Sense kit at the moment. Proformas send.
quan 4 DC Sense kit
loek 2 DC Sense kit
DC Sense kit GB
quan 4 DC Sense kit
loek 2 DC Sense kit
taccodude 2 DC Sense kit
Sum of 52 DC Sense kit at the moment. Proformas in sending.
P.S. Update: Proformas already sent. After payment confirmations received, goods will be shipped promptly.
quan 4 DC Sense kit
loek 2 DC Sense kit
Hi, LC,
Could add me for 4 DC sense kit? Thanks! 🙂
quan 4 DC Sense kit
loek 2 DC Sense kit
Mark Verhoeven 2 DC Sense kit
jokari69 2 DC Sense kit
James 4 DC Sense kit
Sum of 60 DC Sense kit at the moment.
James
quan 4 DC Sense kit
loek 2 DC Sense kit
James
Today I finished FO and I got a Problem with it.You can listen with normal level and after that , the Amp goes on and off.Can SMPS be broke? Before with normal PSU everything worked ok.
SMPS?
Easy to figure out, looking at your rails, first.Today I finished FO and I got a Problem with it.You can listen with normal level and after that , the Amp goes on and off.Can SMPS be broke?
And, if you can see a cutoff of the power supply, to test-it with a power resistance for to little less than max amps it is supposed to provide.
Please try to reconnect linear PSU and if FO works normally, then SMPS is broken. I'm sure Hypex will exchange it in warranty period without questioning. 😉
Probably a stupid question (I am a newbie in this)... Is there a quick guide on what connections I need to make? I think I have it figured, but just want to make sure that I can get this built. I would very much like 12V trigger in/out functions, and my understanding is that the SMPS that has been mentioned here does not have the 12V out capability ? The reason is that I would quite like a monoblock arrangement and I need to modify my current DAC/pre-amp to put out a 12V trigger out > trigger in on one monoblock > trigger out to other monoblock.
Look into post #838 😉
BTW SMPS1200A400 has everything:
- unregulated +/-63 V main DC output
- unregulated +/-21 V auxiliary DC output
- regulated +/-12 V auxiliary DC output
- +12 V trigger input
- DC error input
- amplifier enable output
Regards, L.C.
I just got + - 59V from SMPS,is that normal ?
I have DC +- 60.5 volts.
Output voltage is related with input ac voltage.
The lower you have the better in long run.
DC sense
I must be honest ,
Not buying any First Ones , Love them though ! Very nice concept !
Read all the posts , (Most are) very educating
Would like to order 6 DC sense PCB's for some other project .
Can't make them myself in that quality for that price .
Thanks and cheers ,
Rens
I must be honest ,
Thanks and cheers ,
Rens
- Vendor's Bazaar
- First One - mosFET amplifier module
