First One - mosfet amplifier module - Page 344 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 14th November 2016, 01:19 AM   #3431
fluid is offline fluid  Australia
Some more info, they do come in different configurations and sizes depending on what capacitors you want to use
https://www.aliexpress.com/af/Empty-...fi&blanktest=0
25mm snap in caps will fit the board I have but 30mm is too big.
There is also pads for 5mm pin spacing bypass caps.
Old 14th November 2016, 06:37 AM   #3432
Eric06 is offline Eric06  France
Hi Mark,
You may also check for "High-power Single Bridge 25A Rectifier Filter Power Supply Board For Amplifier" on ebay.
Old 17th November 2016, 06:18 AM   #3433
hose4 is offline hose4  Slovenia
Default Analog dac with fo1.4m
As i am waiting for my own unit i borrowed an msb analog dac.
As a complete system it was really not bad, not bad at all.
After some adjustments and playing with different cables, a wow moment.
Maybe I cured my upgradeitis, but probably just went dormant.
Happy times,
Old 17th November 2016, 07:17 AM   #3434
Lazy Cat's Avatar
Analog DAC, best one I've had in my system, not counting audition of MSB Select DAC or showroom's shots
Old 17th November 2016, 09:38 AM   #3435
Andrej,
I am trying to get all the parts needed to build a new amp. Can you please tell me which connectors are needed for connecting the DC sense modules to the Hypex SMPS and the connectors needed for input to FO 1.4?
Thanks,
Mark.
Old 17th November 2016, 12:43 PM   #3436
I received the FO and DC sense modules today and found out already.
Old 18th November 2016, 07:22 AM   #3437
Andrej,
I've seen in the schematic for the FO 1.4 the grounding layout has been revised compared to the schematic for the FO 1.2. Does this apply to the 1.2 version too, or should it only be used for the 1.4?
Mark.
Old 18th November 2016, 12:47 PM   #3438
Lazy Cat's Avatar
Mark, use grounding layout for v1.4
Old 18th November 2016, 06:07 PM   #3439
Of course I will grounding layout meant for v1.4 with my new modules. I would like to know what is the prefered layout for the v1.2 modules.
Old 18th November 2016, 10:18 PM   #3440
Lazy Cat's Avatar
I couldn't be more clear, in respect of logic.
800 Watt MOSFET Amplifier Module The Saint Aussie Amplifiers 75 18th July 2013 11:16 AM
MOSFET POWER AMPLIFIER MODULE IN EBAY INDIA reji Vendor's Bazaar 0 19th March 2013 01:52 AM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 01:02 AM
NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale magnum_1 Swap Meet 16 13th June 2009 03:59 PM
Help with Mosfet module please Beejay Solid State 6 11th September 2008 03:21 PM
Copyright 1999-2017 diyAudio
