LC, I just swapped R3/R4 to a 100ohm resistors as I'm going to use FO1.4M amplifiers with Hypex smps1200A180 (46V) and would liked to ask what would be recommended VAS idle bias and supply idle bias currents? (recommended values for 63V is 18 and 280mA).
TO USE FIRST ONE M with a Tube pre ( Lua Serenada MK II) I woul like to increase the input impedance to 47 kohm. Would this be ok?
This topic was actually explained a long ago, nevertheless we can do it again. Input impedance of the First One module could be raised to 25 kOhm without serious degradation of noise, stability or DC offset performance, although an effect is linear, higher Zin value is not recommended. Anyway preamp connected will dictate much lower impedance, in a case of Lua that will be 600 Ohm (output impedance) across interconnect cable, so cable's influence on the sound will have much more important role here.TO USE FIRST ONE M with a Tube pre ( Lua Serenada MK II) I woul like to increase the input impedance to 47 kohm. Would this be ok?
Offer already sent on 16th Jan, resend today, no new emails received. 🙂LC,
PLEASE check your email.
Thanks.
--Lenard
LC,
Hmmm. I sent you several emails after receiving your proformas email.
I just sent you another requesting one for a C1 case. Can you confirm?
Thanks.
--Lenard
Thanks.
--Lenard
Heatsink Q
If using a separate SMPS3KA700 to power each L module, what is the minimum K/W rating required for each heatsink?
Studley, FO L needs at least 0,33 K/W heatsink's thermal coefficient to set proper bias at +/-85 V SMPS. Fischer Elektronik SK159 or SK533 (100 mm lenght) are OK. 😉
Thanks Andrej.
Are you planning on offering a stereo or monoblock enclosures suitable for the L modules?
We are looking at great builds here!
Dear Zas,
Congratulations for a beautiful case.
IF you prefer passive volume control, please consider Transformer based Volume Control (TVC) as it works great with the FO. It has various advantages like BAL/unBAL in/outs possible configurations, galvanic isolation, possibility of wiring as autoformer for claimed optimal linearity (which I have not used, as it defeats the former), very dynamic sound with high Vout sources as the EMF is conserved.
Amicalement,
M.
This is an interesting thought. The designer of the DACs I will be using strongly recommends use of the balanaced outputs. I happen to already own a TVC so I could use its RCA output to feed the FO. I wonder how this would compare to the That 1200 option? Thoughts welcomed.
Also I have an active set up and the other amps I'll be using have a gain of 26db. I could therefore use the TVC to attenuate the 27db gain of the FO with the volume control in a fixed position - overall system volume control would be done with the digital volume control of the DAC.
Here's photo instructions how to upgrade existing First One amplifier with capbanks, in simplest way. 😎
Andrej
Do your cap banks offer any advantage over this simple method of increasing capacitance? I ask because I have some suitable caps sitting in a drawer . . .
Ian
Andrej
Ian
Hi Studley,
the bankcaps are made with 2 AudioGrade mlytics 3300u/100V each having 41miliohm ESR, this is high quality caps so if you have other caps , make sure they desserve it.
More caps on the SMPS rail will bring better (smaller) impedance and therefore beter capability to deliver pike current, and they will also smooth the 100hz ripple, which will have good impact to reduce IMD and then better sound.
LC bankcap also includes a wima 220nf and a duelund bypass as an option. So this demonstrates that tuning the SMPS impedance is a complex task and not just pluging caps here and then 🙂
but be carreful their was a post (I think from fab) saying that the hypex PCB came to smoke with 15mf per rail (from my memory)
Thanks maxidcx. You convinced me that I should use LC's cap banks. Do they have to be mounted on the heatsinks as LC has shown in his photos?
Also, I know you talked earlier about using the That 1200, so I'd be interested in your thoughts re my post number 3651.
Well the bankcap will be more efficient as close to the FO as possible, this is the only guidance for placing it.
That1200 with proper +/-12v reg (like hypex HRx) will give you very highend results. But if you use 2 smps as recomended by LC and if you organise the cabling so that the 2 gnd converged as close as possible to the source gnd, then I foresee no benefit with differential
Studley,
He doesn't have any more cases. I just got a private mail from him. Apparently, he is going to go into business selling a variety of FO components (e.g., PRE/DAC, AMP, SERVER) so he stopped offering them.
I asked him when this happen and am awaiting his reply. I'm curious what the pricing will be for the FO amps. I guess it will depend on his target market.
--Lenard
Studley,
--Lenard
Err, will the kits we know still be available at the similar prices? I am quite interested in the FO M modules, and why not a clever PRE/DAC à la Mytek but for DIYer at affordable money.
I hope LC's DIY bits stays as it is... why not aside finished products (as he offered) as these have for sure a market for non DIYer.
Claude
Claude
Claude
Claude,
It was just the cases that he wasn't going to sell anymore. At least that is how I understood it.
Who knows, maybe he figured that it would take away the incentive to purchase the finished product if he offered a full DIY kit.....maybe it is a sign that his FO products will be competitively priced compared to DIY! 🙂
--Lenard
Save
Save
Save
Save
Save
Save
Save
Save
Save
Save
Save
- Vendor's Bazaar
- First One - mosFET amplifier module
