New 1080P USB microscope for easy SMT soldering - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 25th November 2013, 02:13 AM   #1
Default New 1080P USB microscope for easy SMT soldering
Feature:
* 15cm working distance
* 1080P 30fps video, object size is 31mm(1920 pixel) x 17mm(1080 pixel) at 15cm working distance
* Equipped with tailer made megapixel lens, edge to edge sharpness
* UVC compatible, no driver is needed in windows 7 for 1080P operation
* True hardware 1920*1080 pixel high quality non-interpolate Large CMOS sensor
* Aluminum Stand with precision height adjustment
Old 25th November 2013, 02:40 AM   #2
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Now that is what I need !! [and a steady hand]
Got source? and Price?
DIYINHK is the source?
Thx-Richard Marsh
Old 26th November 2013, 03:19 AM   #3
dchisholm's Avatar
Here: "True 1080P High quality microscope for SMT soldering" at DIYinHK http://www.diyinhk.com/shop/home/48-...icroscope.html
As best I can tell from the ad it looks like a very capable tool. The aluminum stand caught my attention - if it's manufactured with as much attention to detail and well-fitted components as the pictures seem to show, it speaks well for the entire instrument. It's also US$300 in price. Small change by commercial standards, but rather pricey for the majority of hobbyists.
I mentioned a lower-cost alternative (including a sample display image) at Discrete Opamp Open Design The company that makes it (IPEVO) now has two newer models which look interesting, though I don't know if they would be especially well suited to working SMT boards.
Dale
Old 26th November 2013, 03:40 AM   #4
Should this be in vendor forums if diyinhk is starting a thread about their new product?
Old 28th November 2013, 05:14 PM   #5
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Is it mac compatible?
/U.
DIY projects blog
Old 2nd December 2013, 09:10 PM   #6
PedroDaGr8's Avatar
As noticed at eevblog this is a Microsoft Lifecam Studio with a lens attached to the front!
FS: New 1080P USB microscope for easy SMT soldering - Page 1
Old 2nd December 2013, 09:59 PM   #7
yes, it's microsoft 1080p lifecam studio! the sensor quality is guarantee
after trying many sub100 vga(fake megapixel) microsope, I decided use sensor from famous brand
microsoft 1080p lifecam studio =$99.95MSRP (~60 market)
Stand = ~60+30(added parts)
megapixel lens =90
plus testing and assembly
if there are enough person have interest, and just order the parts for diyer to modification, the cost can be down at less 70%(not including lifecam studio).
but be careful when modding, I permanently damaged 3 lifecam studio during modification before perfect mod. of every later one
Old 2nd December 2013, 10:02 PM   #8
/U.
it's based on microsoft lifecam studio 1080p,
I found there is review using this cam in mac
mactaris.blogspot.com/2012/05/microsoft-lifecam-studio.html
it should be the same
Old 2nd December 2013, 10:45 PM   #9
Pano is offline Pano  United States
Pano's Avatar
Moved to Vendor's Bazaar. If this becomes an open DIY project, we will move it back
Old 2nd December 2013, 10:55 PM   #10
megapixel lens =90
I missed to add this one also has Cree LED lighting = ~30
but i decide to remove it for a more friendly lower cost in future. The LED make it more convenience to use, but the assembly process is harder. Normally, all external lighting can be used but not as compact as builtin lighting
Found a good article on using a microscope to check stylus wear ALustyGhost Analogue Source 0 17th November 2008 01:53 PM
Distortion microscope? wimms Solid State 34 26th April 2005 08:41 AM
Intel Microscope QX3 cyber_thought Analogue Source 1 8th February 2004 12:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
