SDA-400 Professional multi-way - Page 50 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 21st February 2014, 11:52 AM   #491
Darb is offline Darb  Switzerland
UPS is very fast, but I live in the mountains and UPS does not come so far ...
My package is in the Post office and I'll get late in the day ...
thank you!
Old 22nd February 2014, 12:32 PM   #492
we417 is offline we417  Norway
What type of led do I use for indicating clip fault on/off?
Old 23rd February 2014, 12:18 PM   #493
AP2 is offline AP2  Italy
Banned
Hi ,
You can connect direct on CN (input pcb) without res.
Right "CLIP" is better orange High-Light. (others as generic LED)
For on/off, you can use simple 1-pole permanent switch, connected on CN5(2PIN) and add a Led in parallel,via resistor 470R-1K depeand light.(see polarity on CN5)
Blink at start and immediately turns off. Simple scheme is on thread.
Old 23rd February 2014, 12:26 PM   #494
Banned
Hello Amateurs,
I'm ready to offer the first High-End in Kit.
Two version:
The Mda-400-Kit1:
Complete of all in photo (need only a empity case 1U)
The MDA-400-Kit2:
Includes stereo case, 4 color top/bottom cover available (of 6 final)
Power Output 2x340w (4R) 2x520w (2R) SIN 1Khz
Both kits, they use anodized aluminum frame, which allows easy mounting in any case 1U, as well as offering a product tested in terms of EMI / RFI shielding and thermal performance. (the maximum excursion as Delta, is 25 in any condition of use.
The kit also,includes 4x special wire (for speaker connection), made ​​of pure copper 2mm diameter, solid (very flexible), covered with a polyester sheath.
This ultra compact dual mono, has a current into the load of 32amp peak per channel, perfectly repeatable as audio transients.
....A good reason to listen good music or... impress your friends
P.S. I want to take this opportunity in this forum, so I need a list this week, just to know if I can keep confidential the 20 kit that I have.
Needless to say, in a week, I received from 'Italy 60 order (1 week), do yourself a little deal.
Continue...
Old 23rd February 2014, 09:36 PM   #495
I received my package :-) ... Impressed by the packaging, very nice...
The quality of the whole is more than excellent, I would quickly connect all this to apreciate this quality amp but ...
But i'm missing some connectors ...
There were only 4 parts thereof, (and I've broken one ...)
And no molex 4 pin...
The sink hole is too small for the screws;
Ok these are just details ...
I have to buy some components for another project. I become crazy wenn i try to find everything I'm looking for ...
Roberto can you give me references/name (or a link) of connectors for the Colour Coded Ribbon Cables because I can not find this product ...
Is there a need for a heatsink for sda400 module?
Old 24th February 2014, 06:51 AM   #496
Banned
good day,
Dear Darb, is a cruel fate, nice products with some stupid mistakes, I am mortified by these happened.
For the heatsink, this is a defect in the mechanical processing.
Ah .. no doubt about that, right now I have a person only for the control of all the parts, one by one before the closing of the package.
To see the connector IDC10PIN it.farnell.com/amphenol/t812110a100ceu/socket-idc-2-54mm-a-10-vie/dp/2215232.
For the Heatsink, you have the possibility to increase the hole at 7mm diameter x 6 mm depth?
The SDA-400 does not require a Heatsink, if you can find a simple "L", it can make better fitting.
What kind of speakers do you have? The SDA + DPS-500/52V, has considerable fast high-current on load....you can imagine, only when you listen to
P.S.
If you do not have urgency (as one wek), I can ship small packages, via Post-IT.
Obviously replace the Heatsink also.
Your country is strangely expensive via UPS, I paid 60 €
Old 24th February 2014, 07:19 AM   #497
Thank you for the information Roberto,
I have found the amphenol connector one minute before you reply me... @ farnell...
But i can't find the "molex" female 4 pin that goes on the sda400... I not understand, it's a common connector...
Did you have a link on farnell web site?
For the heatsink it's not a problem, a friend can help me for making this hole a little bit bigger
Don't worry for this very little mistakes...
My speaker are DIY and i am going to make a system with active multi amplification. Your sda400 will be used for bass, for this I need a amp with good damping factor and here I think your system will be perfect. In the meantime I will use your amplifier only... when it will be ready ...
Old 24th February 2014, 08:26 AM   #498
Banned
Is a normal female connector, 2.54 step,in line, made ​​by many manufacturers.
We buy directly, so I do not know at the distributors good for DIY.
I find this at Mouser. seem that molex changed the shape..
Old 24th February 2014, 11:18 AM   #499
Banned
The dimensions can help to choose a enclosure different. in this forum and on ebay, there are some nice case compact, cost around U.S. $ 30-40.
Thanks to the frame in AL, mounts easily with 4 screws.
If Your case have 50mm internal height, PBTU-3 can assembly in vertical also,this reduce depth -25mm
Old 24th February 2014, 07:46 PM   #500
Hello,
I'm in for a kit 2. I'd like to know the price though
Originally Posted by AP2 View Post
Hello Amateurs,
Two version:
The Mda-400-Kit1:
The MDA-400-Kit2:
Continue...
6v6 PP maggie with Polk SDA 1C mackinthebox Tubes / Valves 2 15th November 2010 05:32 PM
Polk SDA-1b's jagster Multi-Way 1 12th May 2008 07:50 PM
Polk SDA 2B FS make offer 00600 Swap Meet 0 15th September 2007 01:40 AM
SDA in OB experiment Kensai Full Range 0 20th February 2007 06:50 PM
Copyright 1999-2017 diyAudio
