Hi JanpoHi Chris,
looking to get a replacement for an old VxD and this thread looks promising.
I was kinda hoping to use my Mesmerize as output buffer.
What's your opinion, would that be feasible ?
Should work well, the kit is reviewed here as a DIY build. https://www.stereonet.com/forums/topic/563813-latest-passive-ldr-attenuatorpreamp-kit-build/
Let me know if any questions arise.
Cheers / Chris
If so, you could have adjusted the LDR board trims with our instructions. The new model improves, by having separate supplies for shunt and series sides of the circuit, as well as separate current sinks for both , and retaining ability to align, if that is required. In some systems owners need method of adjusting balance rather than the usual equal settings, and there is capability of that too.
