VSSA Lateral MosFet Amplifier - Page 98 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 10th April 2013, 02:21 PM   #971
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Send a message via MSN to AKN
Originally Posted by PMI View Post
I think the trimmers are intended to be removed, measured, and replaced with matched surface-mount (?) resistors. There is a pic with surface mount trimmers somewhere here.
I think the explanation is found here: http://www.diyaudio.com/forums/solid...ml#post3432482
/ Anders
Old 10th April 2013, 03:18 PM   #972
ColinAlex's Avatar
Default Capacitor size?
Originally Posted by Lazy Cat View Post
Hi guys
Only 8 parts - capacitors would have to be provided by each GB member individually:
- 10 uF MKT, 2 pcs/PCB
- 1000 uF/50 V, 4 pcs/PCB
- 2200 uF/6,3 V, 2 pcs/PCB
Hi LC,
What's the lead spacing of the 1000uF/50V? Digikey has them available as 7.5mm and 5.0mm.
Your successes can lie to you but your failures never do.
Colin
Old 10th April 2013, 03:51 PM   #973
ColinAlex's Avatar
Default Oh dopey me.
Sorry, found the answer. Post 705.
Colin
Old 10th April 2013, 04:13 PM   #974
Whouaou.
It looks terrific. So to make it short can I still be in the GB ?
Old 10th April 2013, 04:30 PM   #975
Telstar is offline Telstar  Italy
- 2200 uF/6,3 V, 2 pcs/PCB[/B]
These capacitors should be, as recommendation for the best sound, of top quality available.
I suggest you all to install Vishay-Roederstein and Nichicon, as the best results so far were achieved by these two brands.
Please remind us of suggested parts in the BOM
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 10th April 2013, 05:40 PM   #976
Tyimo is offline Tyimo  Hungary
I think the explanation is found here: VSSA Lateral MosFet Amplifier
Thanks!
Unfortunately they are not in the schematic....
Old 10th April 2013, 05:41 PM   #977
How critical are the values of the 22pF and 100pF caps??? Should I use bigger values?
Old 10th April 2013, 07:45 PM   #978
Lazy Cat's Avatar
Exclamation VSSA GB material info
Originally Posted by androuski View Post
Whouaou.
Yes, there will be 250 sets in this GB, so at this time there are still some 30 PCB sets available.
Capacitor dimensions for VSSA PCB:
- 10 uF/63 V, MKT, Vishay-Roederstein, 2 pcs
Lead Spacing: 15 mm
External Depth: 8.5 mm
External Height: 17.5 mm
External Width: 18 mm
- 2200 uF/6,3 V, FG, Nichicon, 2 pcs
Lead Spacing: 5 mm
External Diameter: 12,5 mm
External Height: 25 mm
- 1000 uF/50 V, FG, Nichicon, 4 pcs
Lead Spacing: 7,5 mm
External Diameter: 16 mm
External Height: 31,5 mm
Three preinstalled SMD trimmers will be permanently located on PCB, type 5 tourns, Bourns, for DC offset/VAS bias (2) and output bias (1) setting.
I will also add a Kapton insulator for TO-247 and two plastic spacers for TO-126.
Assembling and calibration will be straightforward and very simple.
Regards Andrej
First One VSSA First One reviews
Old 10th April 2013, 07:57 PM   #979
Idefixes's Avatar
Send a message via ICQ to Idefixes
Lead Spacing: 15 mm
Lead Spacing: 5 mm
Regards Andrej
Andrej you are
Marc
website : http://audiyofield.wifeo.com/index.php
Old 10th April 2013, 08:56 PM   #980
wewe is offline wewe  Sweden
Dear Lazy Cat if its possible, not to late i will take 1 set for stereo
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 53 2nd November 2006 01:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright 1999-2017 diyAudio
