VSSA Lateral MosFet Amplifier - Page 97 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th April 2013, 02:42 PM   #961
PMI is offline PMI  United States
Originally Posted by Rick G View Post
Use the search this thread function. Search for VSSA BOM.
In other words, you don't know either...
Jokes aside, if you mean the one posted on March 19, I printed it out two weeks ago. That was post 705. I did not come across a definitive list of what is not assembled on the GB circuit board, and not included in the GB, although I suspect there is one somewhere in the intervening 250 posts, therefore my Q.
(feel free to seach for the meaning of the work 'definitive") in your most convenient online dictionary... )
I like to plan ahead. Just for an example, the Vishay MKT cap is only available from my preferred distributor with a $20 freight charge. While that is not a big a-$$ deal, and I like to avoid unnecessary surprises, like having to stack up spacers, just b/c an exactly 2-mm thick insulator does not happen to be on hand, etc...
Old 9th April 2013, 03:07 PM   #962
Rick G is offline Rick G  United States
Rick G's Avatar
No offense taken. In that case, you are correct. there is no 'definitive" list as of yet. LC is still working on what he can get preassembled on the boards.
Old 9th April 2013, 06:18 PM   #963
maxlorenz's Avatar
I think soldering (and desoldering) SMD parts is entertaining and even therapeutic, but ordering the parts for the BOM is very boring and fatiguing...
I wouldn't mind if I have to assemble it all by myself and I wouldn't mind either if "someone" could send me all the parts needed...group buy???
Just an opinion.
M.
Old 9th April 2013, 06:30 PM   #964
Within one area, that might make sense... especially if you have a part that costs $2-3 and has a $20 shipping charge like that Vishay cap with 15-mm spacing...
...3-4 different continents not so much
Either way, if one uses power supplies for around 100 Euro each, this will not be a cheap build!
Old 10th April 2013, 01:57 AM   #965
maxlorenz's Avatar
You're right. It's only laziness from my part.
I can order through RScomponents, pay their high prices and forget about shipping troubles...or through Digikey...
Anyway, I think I'll also build the original VSSA with the parts available in the parts box.
Old 10th April 2013, 09:45 AM   #966
Lazy Cat's Avatar
Exclamation VSSA GB INFO
Hi guys
Hope you're doing all right.
As you all probably know VSSA PCB-s are in the production and will be finished probably later next week.
I just want to notice that all SMD material will be preinstalled and the rest of the semiconductors already in the package.
Only 8 parts - capacitors would have to be provided by each GB member individually:
- 10 uF MKT, 2 pcs/PCB
- 1000 uF/50 V, 4 pcs/PCB
- 2200 uF/6,3 V, 2 pcs/PCB
These capacitors should be, as recommendation for the best sound, of top quality available.
I suggest you all to install Vishay-Roederstein and Nichicon, as the best results so far were achieved by these two brands.
Next info will be about the pricing and addresses. Will be in touch soon.
Old 10th April 2013, 10:24 AM   #967
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Thanks LC.
I emailed my details (as requested) a few days ago. I assume that you will invoice by email/PM when all costs are finalised.
Old 10th April 2013, 11:42 AM   #968
maxlorenz's Avatar
Excellent!
Thank you Lazy Cat.
M.
Old 10th April 2013, 11:50 AM   #969
Tyimo is offline Tyimo  Hungary
After you set up the mentioned bias at first you have to use the two (one each side) trimmer to get read of the offset totally, after full warm up readjust it.
I cann't see any trimmer on the sides in the schematic. Only one in the middle.1K That is for biasing.
Old 10th April 2013, 01:44 PM   #970
I think the trimmers are intended to be removed, measured, and replaced with matched surface-mount (?) resistors. There is a pic with surface mount trimmers somewhere here.
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 53 2nd November 2006 01:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright 1999-2017 diyAudio
