VSSA Lateral MosFet Amplifier - Page 95 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 3rd April 2013, 10:20 PM   #941
AVWERK is offline AVWERK  United States
AVWERK's Avatar
If not to late, i,ll take a pair also?
David
Old 4th April 2013, 01:39 AM   #942
OZAM is offline OZAM  United States
Default VSSA PCB.
Please add me with one pair.
Thank you.
Old 4th April 2013, 12:54 PM   #943
chunek is offline chunek  Singapore
Originally Posted by Lazy Cat View Post
VSSA PCB gerbers already prepared. This week I'll visit three PCB+SMD assembly companies and choose the one to produce VSSA.
Two MUR160 transformed to SMD, now ES1D, Vishay, also preinstalled. I'll also try to set faston terminals to be preinstalled
There will be only 6 electrolytic capacitors, two MKT capacitors, two BCs, KSA/KSC and ALF mosfet to solder manually.
Thanks LC,
That will solve my worry on installing SMD parts!
chunek
Old 4th April 2013, 01:42 PM   #944
Banned
Originally Posted by maxlorenz View Post
Is somebody can advice improvements to the circuit, I'm all ears...eyes...
Nice Linear PSU schematic with good care of diodes switching parasitic harmonics. Can be improved (may-be ?) with dumping network at the trasfo coils, and, ('i'm sure of that) just paralelling Zener or voltage regulators to the gate capacitor in order to regulate-it.
L.C, i am just asking myself a question. If we use a regulated SMPS, with HF switching frequency, could we have some benefits to use big film caps (lower F value, less inductance) instead of lytics for the input stage and VAS DC filters of the VSSA ?
Old 4th April 2013, 03:56 PM   #945
Lazy Cat's Avatar
Now we have 10 Ohm and 1 mF/50 V filtering for the VAS/input stage DC rails, since T=R*C, the filtration is effective from 100 Hz up. If SMPS has 100 kHz we could use let say 1 uF/10 Ohm for the same HF ripple filtration job only. But there's also ripple caused by LF loading currents, so something in between 1 uF to 1 mF is probably correct to choose. My suggestion would be still to use quality 1 mF/50 V electrolytics like Nichicon FG or Panasonic FC or ELNA Silmic, etc. Smaller film capacitors would serve fine for HF decoupling but will not be really effective for filtration and current providing in LF audio spectrum, especially when amp's hardly loaded.
VSSA has already 1 uF multilayer SMDs parallel to all electrolytics at DC rails, as I know well that you don't like that much because of cap resonances, but until now they've proved to be done very good job in the circuit.
Old 4th April 2013, 04:12 PM   #946
I think you have forgotten the 2xpi bit, surely its from 16Hz up?
Old 4th April 2013, 07:36 PM   #947
Lazy Cat's Avatar
Yes, 16 Hz would be cuttoff frequency where filter attenuates the signal to half its unfiltered power and that is only -3 dB, which is not relevant to be useful in practice at PSU-s. We usually set PSU passive filters to at least -20 dB attenuation to have useful effect in practice. Concretely at 100 Hz this low pass filter (10 Ohm/1 mF) has only -8,6 dB reduction in power.
Old 5th April 2013, 02:04 AM   #948
maxlorenz's Avatar
Merci bien, cher Esperado,
I suppose you speak about secondaries of TX. I didn't think about that option because T1 disconnect C2 from C1 for a significant period of the cycle...can you explain?
I do not use T2 but many C2's or another reg, the PowerReg which is the only one that I know well how to build: https://picasaweb.google.com/lh/phot...eat=directlink
Sorry for OT (but not too much OT I hope since we want the best PS for SSAs).
M.
Old 5th April 2013, 03:20 AM   #949
Banned
As you know, the high energy parasitic oscillations generated by the switch off of the rectifiers find their way across grounds, primary of the trasfo down to AC lines, generates EMI/RFI. The best is to dump them at the source, whatever the precautions you can take after-it (like T1) to filter them before amp's rails.
The boring point is the optimal RC network depends of each particular trasfo and caps and even the way they are mounted, so it is kind a real life blind try, i don't know an easy way to calculate them.
Old 5th April 2013, 03:23 AM   #950
maxlorenz's Avatar
OK. I understand. I think I have here somewhere some recommendations about this topic...
Amicalement,
M.
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright 1999-2017 diyAudio
