VSSA Lateral MosFet Amplifier - Page 25 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 3rd January 2013, 07:51 AM   #241
Lazy Cat's Avatar
Originally Posted by pergo View Post
two CRDs instead the 470ohm resistors (input pair's collector to rail), improve THD by 30%, mostly 2nd order.
Not the right place for CRD. 15k injection resistor can be replaced with CCS. 470 ohm determine input stage's voltage gain, so by replacing it with CRD would make extremely unstable and nonlinear transfer function. Sims swallow many unrealistic solutions.
Old 3rd January 2013, 08:27 AM   #242
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Not fully satisfied with data i found about small heatsink for VAS i decided ti swap to ones well known and that i have in stock. Miller caps has swap to RF SMD type the more close i could to Vas transistors legs.
Good to use four 1mF as in sch. Nice PCB.
Old 3rd January 2013, 08:31 AM   #243
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Lazy Cat View Post
What do you mean? To combine two amps? Please elaborate Sonny.
At VSSA we are fixed to six transistors only, as promised.
Sorry i forgot about the thread saying only siz transistors.
The only reason to use this output section, is that the current is much lower in every part.
I think with your setting you are at about 20watt per channel instead of 4 - 8 watt per channel!?
But forget about what i have wrote.
Old 3rd January 2013, 08:44 AM   #244
Lazy Cat's Avatar
Two 50 kHz graphs clearly shows 50 Wrms/8 ohm at +/-32 V rails. Settings are: 1,8 mA input stage bias, 15 mA VAS bias, 100 mA output bias and all resistors values as in the VSSA 1.2 schematic. VAS transistors on the main heatsink, TLVH431 as bias spreader set to 1,565 V, Miller caps 12 pF.
Old 3rd January 2013, 02:26 PM   #245
LC, can you please point to the schematic of the bias spreader using TL431. Thanks.
Sam
Old 3rd January 2013, 02:28 PM   #246
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
regarding onboards caps
new develloped small lytics can have very low ESR and high current handling
I would say no poly caps needed, only one lytic cap per rail, thats all
and the VSSA board will look neat and simple
get rid of all those stupid caps
just my personal opinion on it, ofcourse
Old 3rd January 2013, 09:19 PM   #247
Lazy Cat's Avatar
VSSA having VAS transistors on the main heatsink, because of the thermal considerations, require TLVH431 as bias spreader. Once bias is trimmed to proper value, 1 k trimmer can be measured and replaced with two fixed resistors. Vgg fixed to 1,565 V in my case, enabling 100 mA output bias current.
Old 3rd January 2013, 09:25 PM   #248
Idefixes's Avatar
Send a message via ICQ to Idefixes
Latest version with VAs on their own heatsink. 1mF package swap from 12.5mm/5mm legs spacing to 16mm/7.5mm legs spacing because of bigger and easier purchasing possibility. I swap zobel network under board with SMD parts.
website : http://audiyofield.wifeo.com/index.php
Old 3rd January 2013, 10:13 PM   #249
LC, thank you for the schematic. Would you like to give a brief comparison of sound quality between VSSA, TSSA and SSA(IGBT)?
Sam
Old 3rd January 2013, 10:18 PM   #250
neat looking board
looking at small changes
if you move one lytic up, and make the other smaller, you might be able to shrink the board maybe 20%
maybe it would help to make it just 10mm wider
your Vas heatsink design appear somewhat 'space wasting' ?
maybe consider making 'optioanl' mountinghole, somehow
would make optional mounting on main heatsink possible
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 53 2nd November 2006 01:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright 1999-2017 diyAudio
