VSSA Lateral MosFet Amplifier - Page 19 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 26th December 2012, 06:08 PM   #181
Lazy Cat's Avatar
Originally Posted by sonnya View Post
How much current flows in the VAS transistors??
Yesterday I tested only outputs with resistor divider providing Vgg and current was stable at 440 mA, so outputs with fixed Vgg (voltage drop on resistor) have stable bias completely.
VAS current set to 15 mA, very stable (14,5-15,5 mA) before employing bias to outputs.
When both running on the same heatsink, PTC is obvious, so output bias is going up because 2SA/SC gain is rising with temperature.
I will check with reference zener (1-100 mA shunt regulator) as bias spreader so the outputs will have constant Vgg, meaning constant bias, no matter of VAS current fluctuations. In that way cumulative process will be avoided, VAS bias will stop rising at certain temperature.
Old 26th December 2012, 10:34 PM   #182
Lazy Cat's Avatar
TLVH431BQ adjustable precision shunt regulator from 1,24 to 18V, 100uA to 70mA, -40 to +125C temperature range, most suitable to replace bias trimmer for ALF mosfet. In this way Vgg and therefore output bias current will stay constant as once set, regardless of VAS bias current variation. In this case 2SA/SC could stay on the main heatsink to ensure smallest PCB possible.
Old 27th December 2012, 02:38 AM   #183
Hello
I used to have similar problem with these topology. Especially with higher bias.
All do I never mount the VAS to the main heatsink.
wahab made some change in the circuit, I want to see if that will improve the stability.
Also I'm interested how you guys succeed to resolve these issue.
The frustrating think to me the Darlington I used the best sounding amplifier I built over 22 years or so.
Soon I will test the Lat FET version..
I want to hear if will be difference sound wise between the darlington and the FET.
Greetings Gabor
Old 27th December 2012, 06:23 AM   #184
sonnya is online now sonnya  Denmark
sonnya's Avatar
Yes this part fixes the bias problem, but still the bias of the VAS transistors Will be highly depending of the heatsink temperature.
Old 27th December 2012, 06:32 AM   #185
Lazy Cat's Avatar
I'll check the range of VAS bias. The good thing is it won't go below initial setting.
Old 27th December 2012, 09:23 AM   #186
Lazy Cat's Avatar
Greetings Gabor
Hi Gabor
I suggest you to use ALF mosfets, they have low Cgs and high transconductance. I couldn't find better ones for the job in this simple topology. Also they're stocked in Farnell or Newark (Element 14).
I'm sure you'll be pleased with the sound with these new parts incorporated.
Old 27th December 2012, 10:45 AM   #187
supernet's Avatar
I will keep my ears up for any sound comments
Old 27th December 2012, 12:13 PM   #188
AndrewT is online now AndrewT  Scotland
VSSA has 6 transistors.
That qualifies in my book as very simple.
Do I have to read past post1 to discover that it becomes very complicated SA later?
I started reading the SSA and TSSA and had to give up with both because both completely forgot the topic of the Threads ! SIMPLE
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th December 2012, 12:19 PM   #189
lineup is offline lineup  Sweden
lineup's Avatar
This is the latest published version.
It is in post #128
http://www.diyaudio.com/forums/solid...ml#post3298495
It is still simple.
lineup
Old 27th December 2012, 12:22 PM   #190
sonnya's Avatar
Well.. The TSSA first couple of schematics are very simple and they works.
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright 1999-2017 diyAudio
