VSSA Lateral MosFet Amplifier - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 24th December 2012, 07:46 AM   #121
Lazy Cat's Avatar
Originally Posted by gaborbela View Post
Very nice circuit!
Yes indeed, usually we have double matched transistor at input, but here vice versa. Although we can put BC847BPN in input stage in no time.
Old 24th December 2012, 07:50 AM   #122
Lazy Cat's Avatar
Originally Posted by Jay View Post
Khewwwwlll..... It's very easy for you, huh? Looking forward to see the highest (optimum) power possible with this topology (no less than 100W) without sacrificing the overall performance.
That would be CSA circuit, coming soon.
Old 24th December 2012, 07:55 AM   #123
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Hi LC,
need i some value tweakking to keep rail voltage to +/-35vdc as in first version (nice 625Va or 2x300va 2x25vac i have)
Marc
Rails can be +/-35-40V DC without any tweaking. This 1.1 version is just having a little more housekeeping, otherwise the same.
Old 24th December 2012, 07:57 AM   #124
Idefixes's Avatar
Send a message via ICQ to Idefixes
Thats cool....will spend a more little time on eagle.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 24th December 2012, 10:26 PM   #125
Idefixes's Avatar
Here some tryout. BC847BPN is solder on bottom side. Board mesure 80x82mm
Old 24th December 2012, 10:37 PM   #126
Lazy Cat's Avatar
Hi Marc
Thank you for the PCB gift
Marry Christmas dear friends
Old 24th December 2012, 10:45 PM   #127
Idefixes's Avatar
Merry christmas to you LC and to all Diygentleman. LC you play Santa role every time you give advice or support diy stuff here...
Marc
Old 25th December 2012, 10:40 AM   #128
Lazy Cat's Avatar
Exclamation VSSA MosFet Amplifier V1.2
VSSA Amplifier schematic update. RCA input connector and speaker sign with impedance note added. This post is linked to from the first post of the thread to be easy accessible.
Again, this is very good simple amplifier, highly recommended.
Regards Lazy Cat
Old 25th December 2012, 01:24 PM   #129
supernet's Avatar
Very nice
An interesting option could also be to integrate power supply on this board. To have a simple plug & play amplifier.
Most logical way would be to have one rail on left side and other rail on the right side. That means...looking from left side to right side: dual rectifier diodes (TO220), two 4700/50V caps with SMD 0.15 ohm resistor at the bottom for CRC, main circuit, two 4700/50V caps, rectifier diodes. In short...similar like Fetzilla.
P.S.: Merry Xmas to you all too
Old 25th December 2012, 02:00 PM   #130
Idefixes's Avatar
Originally Posted by supernet View Post
Very nice
Have you a link to this particular fetzilla aspect?
Marc
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 53 2nd November 2006 01:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright 1999-2017 diyAudio
