VSSA Lateral MosFet Amplifier - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 18th December 2012, 12:49 PM   #101
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Lazy Cat View Post
No, no, standard parts on 50 x 80 mm PCB, only that I will use these output mosfets, ordered four.
Why 4? did plan to use more than one per chanel???
Will be 8A devices to drive 4 to 5ohms min speakers at +/-35VDC rails?
Marc
website : http://audiyofield.wifeo.com/index.php
Old 18th December 2012, 01:33 PM   #102
Lazy Cat's Avatar
Marc
One ALF08NP16V5 per channel. Look it is simple, for Id=8A you need Vgs=6V, so at +/-38V PSU you get +/-32Vp on the output and that is 8Ap current. This device can do 8A continuos current within SOAR. So perfectly OK for one ALF08NP16V5 to drive 4 ohm at +/38V rails potential and you get out 128Wmax/4 ohm.
Old 18th December 2012, 01:37 PM   #103
Idefixes's Avatar
Who very interesting....i think i have little home work on eagle this evening...
Marc
Old 18th December 2012, 02:04 PM   #104
Lazy Cat's Avatar
Look Marc here's VSSA PCB preliminary. All three transistors to main heatsink, TO-126 will have 2 mm ceramic insulators, so very little capacitance to main heatsink (GND) and still enough heat dissipation. PCB fixed with these three screws only, each 2,2 mF/40V replaced with two 1mF/50V, etc. So you can get an idea ...
Old 18th December 2012, 02:13 PM   #105
Idefixes's Avatar
Rhaaa lovely....will play with that if allow.
Marc
Old 18th December 2012, 02:26 PM   #106
Lazy Cat's Avatar
Originally Posted by tinitus View Post
cool looking little amp maybe time to go build that active speaker
Yes, VSSA PCB will be perfectly suitable for that purpose, just wait a little.
Old 18th December 2012, 07:19 PM   #107
400kg is offline 400kg  Turkey
Banned
Send a message via MSN to 400kg
hi Lazy Cat
Can you do symmetric 50V version ?
Old 18th December 2012, 07:46 PM   #108
Idefixes's Avatar
ALF08NP16V5 board try : 75x66mm
Old 18th December 2012, 08:47 PM   #109
MiiB is offline MiiB  Denmark
Sonny.. Regarding the tendency for the VAS to run thermally away, I have seen that a thermistor across the 470 Ohm rail resister can balance that out. I have currently two amplifiers playing, one bare stripped to simplest basic (like this) and one with everything. CCS's mirror's hawksford-casodes (input and VAS/Driver). Have not yet heard them in the same setup, but sometime during January I will... But first I need to cut some diamond for the CES.
Old 18th December 2012, 09:24 PM   #110
Lazy Cat's Avatar
Very good.
It will take me some more time but will do it anyway.
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright 1999-2017 diyAudio
