USB2.0 to I2S for ES9018 - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 8th December 2012, 03:37 AM   #21
I received many PM asking about the usb99 ES9018 pcb in this month, rather than the USB to I2S for ES9018 PCB..@_@|||||..
The final prototype is finally here^^ 99 includes ES9018chip and PCB, diyer can choose their favour IV component, it's should be more flexible. one audiophile opamp can cost more than 99, of course it's impossible to include in the kit.
The 99 ES9018 PCB uses I2S input(default), it also has SDA SCL connection and oscillator space if DIYer like to play with the unlock problem at asynchronous operation.
The ES9018 requires clock frequency above 40 MHz for optimal operation. The famous Xxxx and Axxxx USB to I2S PCB will have sound distortion problem if used for synchronous operation.
Our USB to I2S for ES9018 interface offers 49.152Mhz/45.158Mhz clocks that can be connected directly to the ES9018 DAC (bypassing the local clock). With synchronous operation you will not only experience better sound, but you can eliminate the unlock problem that many have experienced with asynchronous operation. Other interfaces are designed to operate with oscillators of 24.576Mhz and 22.5792Mhz and thus cannot properly interface with the ES9018 in a synchronous manner. It is the only low cost interface that is optimized to interface to the ES9018 in a synchronous manner.
ES9012 & ES9018 I2S input = half level analog output? Angelm Digital Line Level 0 17th May 2012 11:09 AM
Firewire 400 -vs- USB2.0 external harddrive Fsatsil PC Based 17 4th August 2010 12:51 PM
ES9018 and I2S sjalloq Digital Line Level 3 30th July 2010 11:34 AM
USB2.0 vs 3.0 for SPDIF conversion Salsero Digital Source 0 14th January 2010 11:50 PM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 05:46 PM
Copyright 1999-2017 diyAudio
