Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 13th November 2012, 11:02 PM   #31
tinitus is offline tinitus  Europe
Originally Posted by AP2 View Post
INFO:
I have two "Promotional Test amp" free becouse it not running at 110Vac.
Someone want try this..jewel.
just send me pm.
I suppose you still have the previous PM list in your forum mail box
Old 13th November 2012, 11:06 PM   #32
AP2 is offline AP2  Italy
Originally Posted by tinitus View Post
practical yes, but still no good
it works loose and falls out too easy if anything is moved or touched
ok for hifi
not moved or touched so much, and not fatal if power suddenly fails
for pro use you need to have powercon and speakon plugs
the DPA-400/F2 recommended for bass guitar looks great, but then really ought to have speakon instead of hifi terminals
Sorry, but I disagree. maybe you had a bad experience with some very poor connector. the plug goes into the pan to 18mm and requires pression to put. What move? i have just in this finished amplifier, an AC power cord 16mm diameter.
DPA-400-F1/F2/F3 terminals are used as internal connections...
Old 13th November 2012, 11:33 PM   #33
I dont understand, why so thick ?
mine is just 6mm, and a leftover piece from hedgecutting
but ok for short 3m length
but seriously, since its a devellopment thread, I still suggest to think about using professional connectors
Old 13th November 2012, 11:38 PM   #34
why so thick ?
Aahahh...someone said that running well 6mm..but women not agree..
total voltage drop on amplifier, unfortunately, is a sum of the various resistance and inductance
Old 14th November 2012, 12:03 AM   #35
pro cable
Old 14th November 2012, 12:28 AM   #36
Roberto, is there a back panel for monoblock amp?
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 14th November 2012, 10:13 AM   #37
Send a message via Skype™ to giannettino
I think..yes..
Take a look
File Type: jpg 205895_356070121138912_1332829237_n.jpg (78.6 KB, 147 views)
Old 14th November 2012, 10:45 AM   #38
Yes, this is for 160mm width case. is possible also use very compact 110mmx50 size. toys..? yes a toys that drive a B&W 802 II eheh..
For output connectors (I refer to the modules with the frame), this is the perfect solution from a technical standpoint, and very expensive, it is to be understood as internal connection (from module to rear panel connection).
In this way has permission to use a contact at the module output with very low inductance / resistance in DC, using a special wiring between the terminals and the PCB, soldered with silver.
In addition, I add, these output terminals (external / internal) are the best on the market, not only for aesthetics.
Old 14th November 2012, 11:41 AM   #39
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
pro cable
yup, thats the new powercons, i'm loving them too
Old 14th November 2012, 11:43 AM   #40
hi, I cut out these from your photos, showing the boards only
will these individual boards be available as single parts along with your other accessories parts ?
MDA-400 (Some hidden features) AP2 Vendor's Bazaar 35 18th November 2012 04:28 PM
Promotion: Hi-end Volume Control Module,Ultimate Attenuator for Audio bbp Vendor's Bazaar 18 20th September 2010 03:25 PM
SUPPO AUDIO --The commander EL34 Promotion special spaudio Vendor's Bazaar 5 15th June 2010 03:48 AM
PCB International | Special Promotion for DIY AUDIO members david1115 Vendor's Bazaar 0 17th February 2010 07:39 PM
Krell MDA 300 thermal runaway Solid State 0 8th July 2008 05:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
