| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#21 |
Sorry, but if it helps, I was sitting in my underground lair, planning world domination, and stroking a cat at the time.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#22 |
is choosing a less facetious title...
hmmm OK just this once, as long as I can be assured you will exploit this dangerous demo amp, combined with a callous abuse of moderation power to further your dastardly plans... and those of the greater group of audiopower cult conspirators
![]() too far? hehe Last edited by qusp; 11th November 2012 at 06:17 PM. |
#23 |
So much for proof
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#24 |
Hi, Many people ask me how you can have and the price/parts availability.
Kit Mono: -MDA-400 (250w at 4R setup) (up to 450w on reactive load at 0.04% thd). -Capacitors Bank (blue ELNA LE) -Input board (complete) -All Connectors -All inox screw -Alluminum parts -Special wire 3x(polypropylene, 4x1mm solid pure copper in side), preassembled for Caps-bank to MDA. ----------------------------------- Mono Version €185,00 (incluse VAT 21%) Stereo version €370,00 "" "" €22--30 ship cost (UPS) ---------------------------------- -Rear panel complete as Photo (same parts used) €32,50 (Available only with MDA Amp's) ---------------------------------- This dual mono,have Well playing cards for €3000. Well...this is my contribution at diy's and amator's from Italy. Regards |
#25 |
All pm sended (follow the list for ship) Please, before my brain smoke...put nikName on payments or confirm via pm. ------------------------------------ Coming soon audio measure. regards Last edited by AP2; 13th November 2012 at 07:20 PM. |
#26 |
nice backplate
I know those mains connect plugs are common but they are completely unreliable and useless for pro use why is it called MDA ? new amps shown with speaker terminals are listed as DPA |
#27 |
probably Mono D Amp and Dual Power Amp? the power supplies like DPS600 are likely Dual Power Supply. creative =)
#28 | |
thank for nice backplate. Yes,it is a widely used connector AC, but also in this case, some are of very poor manufactory. we assemble only certified parts. This is the AC Shurter. used with professional ac cable also, no problems at all. I can not assemble in this model, as speak-on AC Input ![]() When i develop this MDA/SDA, "Master Digital Amplifier" and "Slave Digital Amplifier". infact, MDA have power supply bus for one SDA,that is identical amplifier section of MDA. |
#29 |
INFO:
I have two "Promotional Test amp" free becouse it not running at 110Vac. Someone want try this..jewel. ![]() just send me pm. regards |
#30 | |
it works loose and falls out too easy if anything is moved or touched ok for hifi not moved or touched so much, and not fatal if power suddenly fails for pro use you need to have powercon and speakon plugs the DPA-400/F2 recommended for bass guitar looks great, but then really ought to have speakon instead of hifi terminals |
| MDA-400 (Some hidden features) | AP2 | Vendor's Bazaar | 35 | 18th November 2012 04:28 PM |
| Promotion: Hi-end Volume Control Module,Ultimate Attenuator for Audio | bbp | Vendor's Bazaar | 18 | 20th September 2010 03:25 PM |
| SUPPO AUDIO --The commander EL34 Promotion special | spaudio | Vendor's Bazaar | 5 | 15th June 2010 03:48 AM |
| PCB International | Special Promotion for DIY AUDIO members | david1115 | Vendor's Bazaar | 0 | 17th February 2010 07:39 PM |
| Krell MDA 300 | thermal runaway | Solid State | 0 | 8th July 2008 05:25 PM |
