SB Acoustics Satori Monitor - Page 74 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 7th April 2014, 01:38 PM   #731
buzzforb's Avatar
Its a J2 clone. IT is the Kairos kit but with the cab adapted to look similar to Joachim's version.
...Shape the sound , Man!
Old 8th April 2014, 03:15 AM   #732
PKI is online now PKI  United States
PKI's Avatar
Joachim, and what is the actual sensitivity of the speakers? I guess the SPL you posted earlier is not normalized, because it cannot be 90db :-) Can you remind please what is the baffle tilt ?
Old 17th April 2014, 04:17 AM   #733
Dear Joachim, I have got a question for the crossover coil L1021. What is its type and resistance?
Old 17th April 2014, 10:21 AM   #734
Joachim Gerhard's Avatar
Mundorf - Inner Excellence
You can use the Mundorf F50 10 3,5 Ohm. You have to add a resistor of 14,5 Ohm then for a total of 18 Ohm.
Other vendors like Intertechnik or Jantzen make stuff like that too.
This coil most not be of a particular high quality.
Ferrite core is fine.
The slant angle is 9°.
I tell you more about the sensitivity soon.
Old 17th April 2014, 10:25 AM   #735
The tweeter has 92 db efficiency and is dropped by the crossover by ca. 8dB so total efficiency is 84dB. That sounds low but you have to consider that it is 8 Ohm.
Old 17th April 2014, 10:30 AM   #736
Thanks!
I have boxes, drivers and parts for Kalasan 2, but now I will order parts for version 5.
Old 29th April 2014, 01:25 AM   #737
Originally Posted by Joachim Gerhard View Post
Here is the crossover.
HI Joachim,
THX for sharing your know how...I am about to start a 2 way like the kalasan and for cabinet design purposes I have a couple of questions;
1) Does the baffle has to be tilted toward the back (Your cabinet looks to be that way)
2) What is the spacing center to center between the woofer and the tweeter?
3) How far is the tweeter from the top of the cabinet?
Thank you.
Old 11th May 2014, 11:05 AM   #738
Laotzu1 is offline Laotzu1  Denmark
Hi Joachim,
Thank you for a very inspiring and detailed tread.
Two sets of Satori drivers have just arrived, so I am in the middle of designing the enclosures. Do you think it would be a good idea to build some small boxes for the tweeters, or do they need some other damping on the backside to shield them from impact form the woofers?
Old 12th May 2014, 06:55 PM   #739
PKI's Avatar
Are the baffle size and tilt values available for public?
Old 12th May 2014, 11:00 PM   #740
JBdV is offline JBdV  Netherlands
Hi Joachim,
referring to post 1 : "I am designing a two way monitor for SB Acoustics that will eventually lead to a full documented Kit"
When can this kit be ordered and where?
I can wait ...
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2017 diyAudio
