SB Acoustics Satori Monitor - Page 51 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 8th March 2013, 12:02 PM   #501
Joachim Gerhard's Avatar
My measurements where close to the manufacturers specs.
You can look them up on SB Acoustics :: Home
Gonir did also some comparison on www.audioexcite.com
Old 8th March 2013, 02:27 PM   #502
gornir is offline gornir  Sweden
gornir's Avatar
Originally Posted by ttan98 View Post
J. Gerhard,
I quickly read through all the posts here, I did not come across any measurements on Fs and Vas on the Satori. Did you make any measurements on the parameters, Vas and Fs, if so how close are they from the published manuf. data?
They are very close to the published data.
Here you have more info on the Satori 4 Ohm driver:
www.audioexcite.com -- SB Acoustics “Satori” MW16P-4
/Göran
Author of the "AudioExcite Loudspeaker Design" website
http://www.audioexcite.com
Old 8th March 2013, 02:42 PM   #503
thanks
Old 8th March 2013, 10:08 PM   #504
Default Kairos write up posted
I have opened a thread on the Meniscus forum for discussion of the Kairos loudspeaker kit (it is their, after all). There is a link in the thread to download a 23 page pdf write-up on the Kairos design, which covers a lot on the Satori drivers themselves. I know several people here were interested in the write-up so here is a link to the post:
View topic - The Kairos thread • Meniscus Audio Forum
Enjoy,
Jeff B.
Old 8th March 2013, 10:47 PM   #505
Nice write-up.
Unfortunately it does not contain the actual crossover but that is OK out of the reasons you mentioned.
I also made an alternative phase linear crossover but of another type that has the tweeter in phase. It works with a symmetrical rising response near the crossover point.
Lipshitz and Vanderkoy have shown crossovers like that in the late 70th when i studied tele communications but as active filters.
They also have lobing problems so in the end i decided on a 2nd order all pass.
You could argue that this is a 2nd order L/R but that is a bit confusing because some call the 4th order L/R also 2nd order. I think there is no official second order L/R only 4th order. That kind of confusion is typical in engineering. By the way Linkwitz and Ryley have not being the fisrt ones that proposed all pass crossovers.
Old 8th March 2013, 10:51 PM   #506
Here is an interesting write-up that also has references to Garde, Linkwitz and Lipshitz-Vanderkoy.
http://www.essex.ac.uk/csee/research...0crossover.pdf
Old 8th March 2013, 11:01 PM   #507
here you can download a primer with other references :
CiteSeerX — A Primer ? Linkwitz-Riley Background ? 1st-Order Crossover Networks
Attempts to linear phase passive crossover go at least back to 1971, the classic Small paper on constant voltage crossovers.
Really nothing new here but like Jeff said :
The Satoris with their wide frequency response and overlap allow this kind of crossovers to be explored. I think that is good news also it is old news.
Old 9th March 2013, 12:42 AM   #508
Here are some pictures of my current setup. I sit close to the back wall.
The speakers are around 2m from my ears and quite far apart, maybe 3m.
There is no hole in the middle of the soundstage.
The monitors sit on high stands so that my ears are between the woofers and the tweeters.
I cross the Satoris over at 80Hz with a 6dB passive filter to my active M-Dipole bass.
More information soon or just ask me.
Old 10th March 2013, 03:23 AM   #509
Fantastic thread, congratulations to all of you and your dedication and passion
Old 10th March 2013, 01:05 PM   #510
Many thanks.
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2017 diyAudio
