SB Acoustics Satori Monitor - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 4th October 2012, 12:52 AM   #41
Joachim Gerhard's Avatar
Yes, that link has some good photos.
Old 4th October 2012, 03:03 AM   #42
just another
wintermute's Avatar
Yikes they are a tad more expensive than the standard lineup!!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 4th October 2012, 09:24 PM   #43
Yes, but not grotesque like some others.
Today i measured the tweeter. That took longer then anticipated so i will measure the woofer tomorrow. i got a rather detailed analysis though.
Here some pictures from the setup.
Old 4th October 2012, 09:54 PM   #44
I will post the measurements of the tweeter tomorrow.
Old 5th October 2012, 11:01 AM   #45
Here are the frequency response measurements on the Satori tweeter on the 1.2m x 1.2m baffle. The bumps in the response under 3kHz are an artifact of the baffle.
It disappears in the near field response.
The on- and off-axis response was measured in 50cm and the near field response in 10cm.
The measurements where taken at 0, 10, 20, 30 and 45.
Old 5th October 2012, 11:08 AM   #46
Here are the near field measurements at 0, 15 and 45.
The second measurement is in the near field at 45 and 60. The characteristic notch is highest on 45 and shifts down in frequency and depth at 60. That is a geometric artifact because parts of the membrane reach the microphone early and some later from the far side.
File Type: pdf Satori Tweeter notch comparison 45, 60.pdf (18.8 KB, 216 views)
Old 5th October 2012, 11:13 AM   #47
Here is harmonic distortion, second and third, at medium volume and high volume.
The high volume was rather challenging loud on my ears.
Measurements like this are hard to interpret because a comparison can only being made when a competing tweeter is measured at the same volume and distance.
This measurement was also taken in the near field.
File Type: pdf Satori Tweeter harm dist medium volume.pdf (17.8 KB, 366 views)
File Type: pdf Satori tweeter harm dist high volume.pdf (17.8 KB, 298 views)
Old 5th October 2012, 11:19 AM   #48
Here is a multi tone test. 31 frequencies spread in such a way that they do not inter modulate much with themselves. This test is also know as Spectral Contamination.
The first test is with the driving signal and the other shows the multitones notched out so that is a so called Belcher Test.
Old 5th October 2012, 11:22 AM   #49
Here is a single tone spectrum, high volume, at 1.8kHz and 4kHz.
THD in both cases is around 0.55%.
Old 5th October 2012, 11:23 AM   #50
Here is a sigle tone spectrum, high volume, at 1.8kHz and 4kHz.
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright 1999-2017 diyAudio
