Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th January 2013, 08:16 AM   #371
_henry_ is offline _henry_  Australia
perhaps actively? will this be the shallow sub you introduce earlier in the thread?
Old 9th January 2013, 08:21 AM   #372
Joachim Gerhard's Avatar
Yes, active with the shallow sub.
Old 9th January 2013, 09:03 AM   #373
Would someone kindly refer to measurement that show dispersion for the Satori 6" ? Since i belive that it's important to takes this into consideration, when matching it up with a tweeter.
Old 9th January 2013, 01:22 PM   #374
5th element's Avatar
In that regard is it pretty much like any other driver with the same diaphragm diameter. You still need to cross low to achieve good off axis curves around the xover frequency, or mate it with a suitable wave-guide, crossed higher, for a decent directivity match.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 9th January 2013, 01:43 PM   #375
Thank you Better wait for the 5" version then
how do you measure distortion - is it something that "normal" people can do with not to expensive equipment? It would like to measure my own speakers, to find out if I can fiddle with the filter to gain less distortion - and test how choice of xover-freq changes distortion from a given driver arrangement.
Note: using active filters, so changes are very easy
Old 9th January 2013, 07:14 PM   #376
just another
wintermute's Avatar
If you use holm impulse to do measurements, choose the swept sine type of measurement and you will have a distortion tick box that you can tick to show the distortion on the measurements display. You can only show one harmonic at a time though.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th January 2013, 07:41 PM   #377
Tony.
Higly appreciated. Will try that soon
Old 9th January 2013, 09:13 PM   #378
STEPS, part of the ARTA software suite is specifically designed to perform distortion measurement and offers a lot of options on how it goes about doing it.
Hardware wise any decent soundcard + something like the Behringer ECM8000 + a suitable mic pre amp, are all that's required.
Old 10th January 2013, 07:49 PM   #379
Wow, the 6.5" Satori is a impressive driver , once again proved by Zaph.
I use Holm Impulse. Phonic AM120MKII mixer with +48v phantom (same Behringer UB502), Asus Xonar DG (cheap but very good!) and as mentioned above a Behringer EMC8000. Works excellent for distorsion/freq-measurements!
Been using other programs but coming back to Holm everytime!
Old 11th January 2013, 06:20 PM   #380
Hypercubes, starting from dimension 0 up to dimension 6 - YouTube
SB Acoustics 3 ways cosmindaniel12 Multi-Way 18 1st June 2012 05:52 PM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2013 diyAudio
