| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#221 |
Does not bother me at all. The high end of the range is always where they make the margins up. They are probably pushing to keep the L15 within most budgets, and have to get really beaten up by the OEM builders who want it for 5 cents over production. Also remember that the high end is lower volume so the materials cost is a larger jump that you expect. This is why I expect more things like documentation at the high end. It costs them almost nothing, but gives the consumer more value.
The definition of a good deal is when both parties walk away smiling. |
#222 | |
I bet they often buy the cones in from an external source (Chinese most likely) for instance for the pressed cone prestige models. The die cast magnesium cone an in house effort, paper cones from european source, some in UK from Dr. Kurt Müller: Sandwich Cones. After considering that you have to work out the law of diminishing returns for yourself. |
#223 | |
It is as you say though, the Excel driver will more then likely have a much higher profit margin.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#224 |
And a longer development time plus tooling. The Seas magnesium cones are cast and then turned manually on a lathe to make the profile thinner at the edge. Non of the SEAS people i know are any richer then a usual engineer.
#225 |
Oh I am sure they aren't, but what makes the Excel the excel to me is the extra stuff in the motor that lowers its distortion. I am sure they could add this to the L15 for very little, but if they did that there'd be very little point in the W15.
#226 |
Some of the drivers they make for me have a cheeper version of the Excel magnet.
Yes, hybrids can be made that are more affordable. |
#227 |
I've always wondered how specific you can get when custom ordering a driver from somewhere like SEAS. I mean could they make a magnesium coned mid-range specific driver, like the W15 with the neo-hex magnet, which focuses on having reasonably high sensitivity at the expense of bass extension? I've always wondered why they haven't done this anyway.
I suppose the problem with that is if the cone needs to be lighter it would be thinner and that might not have beneficial effects on the break-up. Maybe you cannot change the cone as that might require new tooling.
#228 |
SEAS has over 1000 customers and i have seen 15cm magnesium midranges with hex magnet in the lab. Ether you use the big tool box they have or you invest in your own design. Have being there, have done that.
I have not talked with SB about that but i suppose that is possible. They supply a lot of raw parts to european vendors anyway, including metal parts. When Davis Stevens visited me i showed him some SEAS and Scan drivers and he could identify most parts : this is made by SB, that is made by SB, and so on. |
#229 |
its interesting to see that even seas outsourced the parts to make the drivers.
i can see why sb acoustics can be so competitive as its made in sb factory. |
#230 |
They have a huge factory, they also make cabinets.
I have checked if they ca do my design and they said yes. |
| SB Acoustics 3 ways | cosmindaniel12 | Multi-Way | 18 | 1st June 2012 05:52 PM |
| More T/S specs needed for SB Acoustics | mcmahon48 | Multi-Way | 2 | 15th August 2010 12:34 PM |
| All SB Acoustics MTM ?? | Andy G | Multi-Way | 12 | 26th September 2009 12:35 PM |
| Anybody familiar with SB Acoustics | zimjj | Multi-Way | 0 | 13th March 2009 10:30 PM |
| SB Acoustics... The stuff looks good | sardonx | Multi-Way | 20 | 16th February 2008 08:15 AM |
