Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th October 2012, 06:16 AM   #121
_henry_ is offline _henry_  Australia
great! looking forward for your take on the project.
i did some sb17 and sb15 in the past, they perform very well. i think Satori will going to be excellent performer.
regards
henry
Old 9th October 2012, 04:35 PM   #122
tvrgeek is offline tvrgeek  United States
Passive will give a much wider potential audience to support the vendor. Quite a reasonable choice.
Old 9th October 2012, 04:49 PM   #123
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Why not use the Scanspeak/Peerless HDS tweeter? It has the advantage of being 8 ohms and is proven to sound great and easy for amps to drive.
Old 9th October 2012, 05:20 PM   #124
Joachim Gerhard's Avatar
My job is to do a two way with Satori woofers and tweeters. Therefore i put this project into Vendor´s Bazaar.
Old 9th October 2012, 11:26 PM   #125
I have now measured the woofer and will post the results soon.
I can already say that it is exceptional wide band and clean.
Old 10th October 2012, 12:12 AM   #126
Here is the frequency response at 50cm on the baffle. The other measurement is a comparison on axis and 45° off axis.
Old 10th October 2012, 12:16 AM   #127
The response is exceptional extended, up to 15kHz and that is without a wizzer cone.
Better then some full range drivers. Off axis the response it good to 3.5kHz so a crossover between 1.8kHz and 3kHz is possible. There is a small notch at the edge resonance but you will see that this does not produce distortion.
Old 10th October 2012, 12:17 AM   #128
Here is the near field response in 10cm. That way the effect of the baffle is eroded.
Old 10th October 2012, 12:22 AM   #129
Here is harmonic distortion at medium volume and spectrum at 200Hz and 1.1kHz. This driver is exceptional clean. Second harmonic is the lowest i measured, third is low too.
The 1.1kHz spectrum has just 0.3% THD, the spectrum at 200Hz is around 1%.
Old 10th October 2012, 12:24 AM   #130
with such a natural rolloffs on offaxis in 3khz, i think i really going to like this
cheers
henry
SB Acoustics 3 ways cosmindaniel12 Multi-Way 18 1st June 2012 05:52 PM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2013 diyAudio
