Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 7th October 2012, 11:45 PM   #111
Joachim Gerhard's Avatar
Yes, i know this speakers and heard them on shows. He gave an interview that i found fascinating. I also like the no nonsense styling. The only problem i have is the sharp edge between the woofer and the tweeter. I made experiments with this and got in trouble. He uses a small waveguide though.
Old 7th October 2012, 11:48 PM   #112
I think that his design can be used with some small changes.
Old 7th October 2012, 11:49 PM   #113
gornir is offline gornir  Sweden
gornir's Avatar
How thick is the mid-woofer baffle? My guess is that you need something between 25-30mm?
If so it's better to have the baffle straight at the top to get the center to center distance between the tweeter and mid-woofer as small as possible. If any diffraction causes an issue, use some foam at selected places (NHT style), to diffuse it.
/Göran
Author of the "AudioExcite Loudspeaker Design" website
http://www.audioexcite.com
Old 7th October 2012, 11:53 PM   #114
Here is another idea. sorry to say that i did not invent that ether.
It is a danish design.
On the other hand i am not a big fan of heavy felt damping. It can be an advantage on axis but you loose energy off axis.
I think i go for a Guru Clone. Nice word that is (:
Old 8th October 2012, 12:08 AM   #115
gornir's Avatar
If I was you I would go for the Guru clone.
The loudspeaker in the picture would have some tweeter diffraction isues and doesn't have the right amount of time delay that you require.
I would also use an baffle with of at least 25cm, but that depends on how the mid-woofer measures. This would give an baffle diffraction centered at around 500Hz depending on baffle round-over.
Also I would design the loudspeaker to have the tweeter at ear height or below in order to reduce the baffle diffraction issues.
This could be a great speaker!
/Göran
Old 8th October 2012, 12:18 AM   #116
I think i will mix the Guru Clone with some other little ideas.
It is simple to make, looks good and will do the job just fine.
There are many ways to measure the acoustic center.
One very simple way is to measure the raw response of the drivers with the same time of flight ( on the same baffle of reference, the basket depth difference has to be taken into account too), put that into the simulator, reverse the tweeter and tweak the delay until they cancel most. The other way is to measure the transfer function, do a Hilbert transform,
calculate the excess phase and tweak excess delay until it is flat. That way you have cancelled the amplitude response out of the picture.
Old 8th October 2012, 12:23 AM   #117
I think it is also a good idea to make the speaker somewhat wider then the typical monitor. That is a really good Guru idea. Gives the tweeter better support in its lower reaches and makes the baffle step not that drastic. Yes, i will place the tweeter on ear level and put the acoustic center in the middle of the tweeter membrane. That needs some more delay compensation though then putting the acoustic center between tweeter and woofer. From the geometry putting the acoustic axis on the tweeter it is even closer to the microphone. In the far field ( say at 1m distance or more ) the diffence will be small though.
Old 8th October 2012, 12:27 AM   #118
Ok, when measuring the woofer it has to be placed on the measurement baffle below the tweeter vertically where it sits later.
Old 8th October 2012, 11:58 PM   #119
_henry_ is offline _henry_  Australia
joachim,
i will follow this with interest, i do have satori midwoofer and scanspeak HDS tweeter on hand. i was planning to do OB, but it seems i wont have enough space for them.
So im thinking to follow your enclosure design, and modified passive xover or ACTIVE with MINIDSP using HDS.
what would be your opinion on this?
regards
henry
Old 9th October 2012, 02:02 AM   #120
I go for passive crossover.
SB Acoustics 3 ways cosmindaniel12 Multi-Way 18 1st June 2012 05:52 PM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2013 diyAudio
