diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Vendor's Bazaar (http://www.diyaudio.com/forums/vendor-s-bazaar/)
-   -   FS: My new design: CM6631 24bit/192khz USB to Coaxial and Optical fiber (http://www.diyaudio.com/forums/vendor-s-bazaar/219056-fs-design-cm6631-24bit-192khz-usb-coaxial-optical-fiber.html)
weiliang 4th September 2012 02:50 PM
NEW version CM6631 24bit/192khz USB to Coaxial and Optical fiber
Listing in China for just a month and became a hot seller, a lot of audiophiles discuss the board in China domestic forums. This board with top grade IC chip CM6631 attracts so many audio lovers!
If someone needs it, just PM me.Thanks.
Picture are here: http://www.diyaudio.com/forums/digit...cal-fiber.html
weiliang 6th September 2012 04:43 AM
here is the link selling on eBay, this is my friend's store. also you can pm me if someone want to have a try of this board, thanks.
NEW version CM6631 24bit/192khz USB to Coaxial Optical fiber case by weiliang | eBay
colinyal 15th September 2012 02:46 PM
cm6631 always upsamples 44K to 48K
:mad: I have one of these but it always upsamples 44K to 48K despite all settings be correct to replay 44k native rate in player, asio4all & w7 device supported rates. Tried both hqplayer & foobar (ASIO modes)
48K & 96K replay their native rates OK.
Installed driver is c-media usb2.0 high speed true hd audio 7.0.1.4
ANADIGIT 11th October 2012 03:27 AM
I have many many problem with your device.
Me and my friends bought 9-10 Pcs and some of them not support to ASIO also not recognize to USB2.0 (removed virus scan) also external power supply there're no light and does not work.
Have you test it surely before send them to customer ?
Regard
Anadigit
weiliang 13th October 2012 01:52 PM
Originally Posted by ANADIGIT (http://www.diyaudio.com/forums/vendor-s-bazaar/219056-fs-design-cm6631-24bit-192khz-usb-coaxial-optical-fiber-post3197201.html#post3197201)
Regard
Anadigit
Hello Anadigit,
Where do you get the boards? give me the link, we always ship the items after fully tested and also send the buyer the driver.
ctrange 15th October 2012 07:46 AM
I also have trouble with this device. It not recognize to USB 2.0 and Win 7 64 driver works 24bit 48000Hz Maximum. Installed driver is c-media usb2.0 high speed true hd audio 7.0.1.4
colinyal 1st November 2012 01:21 PM
I sorted this by uninstalling driver w7 installed & installing driver from vendor.
I now have 4 of these units & they are all fine (3 with 88k & 176k firmware).
Always you have to uninstall driver w7 installs & use vendor driver, this is weakness in w7 (XP gives you option to install from location of your choice, which is what you want !).
Also you have to open device properties and tick sample rates supported.
Also if you use different usb socket you need to install drivers again.
mhelin 1st November 2012 01:55 PM
Please consider adding I2S input header for this device as well, it would make nice sound card, too.
newz2000 15th January 2013 02:39 PM
Originally Posted by weiliang (http://www.diyaudio.com/forums/vendor-s-bazaar/219056-fs-design-cm6631-24bit-192khz-usb-coaxial-optical-fiber-post3151807.html#post3151807)
Hi!
I've recently bought another version of your CM6631 board for DAC7 (link). Could you, please, send me firmware for it. I've tried some other CM6631 firmwares found on diyaudio.com, and now need to flash back to original (0101 as I remember).
I've PM-ed you my email.
Thanks.
UrSv 20th February 2013 06:07 PM
Originally Posted by mhelin (http://www.diyaudio.com/forums/vendor-s-bazaar/219056-fs-design-cm6631-24bit-192khz-usb-coaxial-optical-fiber-post3223763.html#post3223763)
I second that. A CM6631 board with both input and output would be great.
Copyright ©1999-2017 diyAudio
