My new design: CM6631 24bit/192khz USB to Coaxial and Optical fiber - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 20th September 2012, 09:52 AM   #21
anbello is offline anbello  Italy
anbello's Avatar
I bought one and arrived yesterday. it's well done and good looking.
I tried it with Linux (Ubuntu 12.04) and it see the board as "Asus Xonar Essence One" and only works in 44.1, 48KHz - 16bit.
Then I tried it with Winodows 7 and Asus driver and it works well at all sample frequencies and bit depth as stated.
On this thread (post #17) I read that exist more option for the firmware (OEM firmware). I would like to know if with the other firmware I can use the board with Linux at 192KHz/24bit and if I can flash the firmware myself.
Andrea
Old 21st September 2012, 03:19 AM   #22
john57 is offline john57  United States
I was able to get WASAPI to work for bit perfect playback on J.River but not ASIO or the WASAPI event style will work on my Win7 64Bit platform besides Direct Sound.
Old 11th October 2012, 06:14 AM   #23
Banned
Are there any reply from this seller ?
Old 13th November 2012, 01:41 PM   #24
I have bought this item from the seller (Weiliang) in taobao.com of China, the build quality is great. It does sound very smooth and musical, but I have experienced the same problem in J.River Media Center 17, I can use "WASAPI" but I cannot use "ASIO" or "WASAPI-Event Style" which is my preferred output.
My guess is the driver from C-Media CM6631 has problem with "WASAPI-Event Style".
Old 16th March 2013, 02:59 PM   #25
Anyone tried this on Mac? Any driver needed? Does all sample rates work?
Old 15th April 2013, 12:45 PM   #26
I bought one of your " CM6631 24bit/192khz USB to Coaxial and Optical fiber" v1.4.
Everything works ok on either pc or mac except no output at 176.4khz and 192khz.
Player (foobar2000,amarra,audirvana) show songs are being played, but no output either at optical, coaxial or i2s. 44.1khz,88.2khz and 96khz are playing beautifully. Any idea what's wrong with product ?
Thanks.
Old 26th June 2013, 09:45 AM   #27
Hi Mr. Weiliang.
I have bought 2 DAC7 with CM6631 USB modules fom minishow seller (user RAZOR2000SHOP). These units work fine but I have a problem with CM6631 when I try to play wave file in 192khz 24 bits resolution. The sound is good but I have also several scratches noise (non periodic). I'm using a TOSHIBA TECRA pc with WINDOWS7 64bits but the problem is existing also with other computers.
Someone told me that is necessary a new firmware. If this is true could you send me the firmware, the installation tool (for WIN7) and the instructions how to do it?
My emai is: roberto.marin@mail.wind.it
Thank you in advance.
R. Marin.
Old 31st December 2013, 07:39 PM   #28
sDieter is offline sDieter  Germany
Default Macintosh Driver
what makes a Macintosh Driver , Weiliang ?
or consumption of any Mac :-)
Dieter
Old 31st December 2013, 07:47 PM   #29
Mr. Weiliang,
I have a DAC7 with CM6631 USB modules fom minishow seller.
but my Mac can not find a USB device on the bus.
Normal consumption of the Mac no driver that is there any different?
Dieter
Old 3rd January 2014, 06:09 PM   #30
Default I myself have found a solution
I myself have found a solution.
Please read on:
XMOS USB on Mac
Dieter
CM6631 usb audio interface .... any good ? i2k92 Digital Line Level 613 5th June 2017 09:33 PM
Hi-resolution source 192KHz 24bit (USB to Analog) audiodesign Digital Source 22 25th December 2011 08:29 PM
High performance DAC mDAC-2v(USB, Coaxial, Optical input) ck210 Vendor's Bazaar 4 6th July 2010 09:19 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
Hiface USB -> I2S 24bit/192Khz audiodesign Group Buys 367 26th May 2010 12:00 PM
Copyright 1999-2017 diyAudio
