Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 22nd November 2012, 08:16 PM   #911
Originally Posted by supra View Post
Your not going to do it with the latest driver/firmware . Frustrating no support or feedback from Amanero here.
There is great support from Domenico, just wait and see (no intention to advertise, no need anyway)
Old 22nd November 2012, 10:14 PM   #912
akira is offline akira  France
Have added my name to the GB3.
Hope it is not too late.
Old 22nd November 2012, 10:20 PM   #913
added myself too for one USB to I2S
Old 22nd November 2012, 10:55 PM   #914
glt is offline glt  United States
Originally Posted by glt View Post
Works like 1.0.5
Requires remapping of DSD channels
Spoke too soon....
Driver 1.0.56 fixes the channel mapping for DSD
I am using firmware prior to September 18
RL channels are correct for:
Direct Sound (PCM)
Wasapi (PCM)
foo_dsd_asio (PCM, DSD)
No need to invert the channels with a custom channel map
www.hifiduino.wordpress.com
Old 23rd November 2012, 05:59 PM   #915
2A3SET is offline 2A3SET  Canada
Default Anyone tried DSD128?
DSD64 is fine, either native or converted with foo_dsd_asio.
With foo_dsd_asio cannot get DSD128 work.
Also I have some problem with 32/384.
Old 24th November 2012, 05:07 AM   #916
Both DSD64 and DSD128 works in my setup. However, I can't lock to 384K (could be the reclocking)
Old 24th November 2012, 01:24 PM   #917
Spoke too soon....
I don't believe you spoke too soon as I have been finding it difficult to get consistency in results?
Old 24th November 2012, 05:28 PM   #918
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
what firmware have you got in fifo? or you mean your point to point reclocking? 384 needs firmware version 3.3 or later and displays as 192 on the LEDs
Old 24th November 2012, 07:01 PM   #919
(I am somewhat ashamed to say :-) that) the FIFO is not in the system. How would I be able to switch between PCM and I2S?. That is why I asked Ian if he plans to update the firmware to allow DSD compatibility. The amount of data in DSD 64 is the equivalent of 2x44.1 and DSD 128, the equivalent of 88X2, so there should be sufficient FIFO memory...
Old 24th November 2012, 07:44 PM   #920
qusp's Avatar
still?
well no you cant, but there is more to the problem than memory size for working with DSD. DSD is essentially an analogue waveform represented in a 1bit stream, the FPGA in fifo is not set up for 1bit..is it?
needs a different module, not just different firmware. myself I dont see whats so special about DSD so far in my system
maybe if there was more variety of music available...
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2013 diyAudio
