USB to I2S 384Khz - DSD Converter - Page 88 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 20th November 2012, 05:38 AM   #871
glt is offline glt  United States
Latest Amanero driver (1.0.54 and. 1.0.55) resamples 44.1 to 48K if using foo_dsd_asio as output device (in order to support DSD). If using eg WASAPI, there is no resample but no support for DSD. 1.0.55 does "fix" the channel inversion with DSD.
Seems the best option is still 1.0.5 with the custom channel map for foo_dsd_asio.
Seems foobar uses foo_dsd_asio for DSD output (bypassing volume control) but some "unknown" path for PCM which still goes through volume control
www.hifiduino.wordpress.com
Old 20th November 2012, 07:28 AM   #872
supra is offline supra  Australia
Originally Posted by Jackal29a View Post
That was changed in V.18 and it is far more convenient than V.17.
1) Update/upgrade to V18
2) Select either Kernel Streaming or a WASAPI mode (recommended Event Style)
3) Tools->Options->Audio->Settings->Bitstreaming->Custom and there check the "DSD Over PCM (DoP)" box and "DoP 1.0 (0xFA/0x05)" in the drop down list
OK I did the update, used the DoP settings and now I get DSD playing on the left channel and noise on the right channel?
I'm halfway there!
Old 20th November 2012, 07:43 AM   #873
That is very, very strange. Does the Buffalo report 48KHz on any PCM input sample rate or only 44.1?
We'll have to ask Domenico what changes could have lead to this problem.
Old 20th November 2012, 12:56 PM   #874
I would like to adress a question to the old users who already purchased this device in the past and are able to give me an answer based on their experience :
Does this board output bitperfect data? I mean is it upsampled or modified in any ways using different algoritms perhaps?
My other question is what standard is the I2S stream that it outputs? is it compatible with the old philips I2S format or is it the newer Sony I2S format?
I am asking all these because I would need it mostly for a NOS TDA1541A DAC that accepts only 16 bits, 44khz so I would have no need of 24 or 32 bits, but I would need it to be bitperfect on 16 bits only - if it outputs 24 bits that means TDA DAC chip would receive the signal already truncated?Is there anyone using this DAC with this setup so can give me a clear confirmation?
Many thanks in advance!
== There are no limitations to the self except those you believe in ==
Old 20th November 2012, 05:27 PM   #875
Yeah, very strange. The "resampling" only happens with 44.1K. Playing say 96K remains 96K.
Old 21st November 2012, 12:51 AM   #876
kp93300 is online now kp93300  Malaysia
Hi
I want to integrate this board with Buffalo 2. I2S
can someone help to confirm the pin assignment --
Buffalo 2 VS AMANERO BOARD
D2 ---------I2S DATA
D1------------I2S FSCLK
DCK-----------I2S CLK
GND ----------ANYONE OF THE GROUND PIN ?
Thanks in advance
kp93300
Old 21st November 2012, 01:39 AM   #877
Look at post 824
Old 21st November 2012, 04:13 AM   #878
glt,
many thanks for the clear drawing !
kp93300
Old 21st November 2012, 05:21 AM   #879
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by kp93300 View Post
Hi
Thanks in advance
kp93300
ideally you should scrape some of the soldermask back on the connector and run a separate ground wire for each signal to the ground plane
Old 21st November 2012, 12:49 PM   #880
Hi there,
if it's still possible, i would like to join myself to this GB, as i'm also ordering the SUBBU DAC V3.
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright 1999-2017 diyAudio
