| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#791 |
#792 | |
All wires must be the same length. Regards |
#793 |
#794 |
ADN4667/ADN4668 seem to give much better layout, 1.5ps RMS jitter contribution by ADN4667/ADN4668 combo thru HDMI cable.
HDMI cables work nicely for I2S transmission.
The missing link between lead and gold in alchemist's world was BS and commerce. |
#795 |
I'm late I know, is the gb still on?
#796 |
#797 |
#798 | |
Thanks |
#799 |
#800 | |
is choosing a less facetious title...
more general stuff for the thread when twisted pear suggest twisted pair can be used, they mean actual twisted pair cable, not home twisted silver wire, but 100ohms ethernet cabling, I favor Belden Cu in PTFE network cable, but yes HDMI is a better cable construction IMO. I tell you what though, nothing beats not needing to drive a long cable to your dac in the first place.... just use an isolator and reclock locally at the dac if you can. people really shouldnt be treating this like a separate peripheral, its part of the dac, it should be as close to the dac as possible, you should not use one of these HDMI or teleporter things just to enable you to install it somewhere you have enough room for your shunt regs... the thing is tiny, you should have room for it in any dac, putting it in another case just so you can use a low noise power supply is walking *** backwards Last edited by qusp; 15th November 2012 at 03:52 PM. |
| HLLY USB SPDIF/ I2S CONVERTER | kp93300 | Digital Source | 12 | 29th January 2012 02:55 PM |
| exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 0 | 11th November 2011 11:41 AM |
| $40 USB to I2S converter | sharpi31 | Digital Line Level | 7 | 12th July 2009 04:09 PM |
