| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
#701 |
#702 |
is choosing a less facetious title...
it has to do with lowering the noise floor that was exhibited with some setups due to a logic timing error. as I understand it the CLPD was active and causing noise in the on time instead of between clock ticks. a few other minor fixes too
edit: oops haha I didnt see the DSD bit |
#703 |
#704 |
Thanks Qusp,
The i2s connections are correct now and firmware updated. Sounds very nice, more open and better impact compared to the Teradac. |
#705 | |
I'm looking at the ES9018, PCM1794 and DSD1794. Would prefer at least 384 kHz/DSD256 but to my knowledge not available in any other chip than the ES9018 (?) - which costs ~ USD 66 from ismosys. BTW any of you know of a less expensive source for these? Greetings, Jesper
... Being mindful about sustainability also in my audio endeavors matters to me ... paying CO2 - and a quite fair pollution - compensation helps create a good listening "energy" ... |
#706 |
Anybody have required values for building 5V Salas PS for Amanero board?
#707 |
Might this be what you're looking for?
Greetings, Jesper Oups, I can see that I can't attach excel spreadsheets. Anyway, salas (I think) has made a spreadsheet that makes calculating values easier. If you PM me I can send it to you - it doesn't show up on a search here but the sheet is named: SSLV1.1 Calculator V1a Jesper
... Being mindful about sustainability also in my audio endeavors matters to me ... paying CO2 - and a quite fair pollution - compensation helps create a good listening "energy" ... Last edited by gentlevoice; 7th November 2012 at 07:47 AM. |
#708 |
And then I have an issue with updating the firmware :-( Followed the steps in the "how to" link:
Amanero Technologies but when trying to download the new firmware, the configtool.exe says "Please erase the Device" ... ? It says so even if I unplug the device... My guess would be that the device is erased already since windows tried to install a new driver when I re-plugged it. Any experiences with this? Appreciate help :-) Jesper
#709 |
Did you follow the instructions on the "How to" page?
After erasing the device you need to disconnect it, and once you plug it in again and it is detected by Windows as an unkwon device you need to install the driver that comes in the same zip as the tool. It will be then identified as an "USB to serial device" only then you can update the firmware. |
#710 |
| HLLY USB SPDIF/ I2S CONVERTER | kp93300 | Digital Source | 12 | 29th January 2012 02:55 PM |
| exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 0 | 11th November 2011 11:41 AM |
| $40 USB to I2S converter | sharpi31 | Digital Line Level | 7 | 12th July 2009 04:09 PM |
