Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th October 2012, 09:09 PM   #511
orpheus is offline orpheus  United States
Originally Posted by Jackal29a View Post
Yes.
Thanks, that helps.
Old 9th October 2012, 09:24 PM   #512
shoom is offline shoom  United Kingdom
thanks Bob and Korben
really interesting to see how you guys are getting on
i'm planing to use Jriver or Fubar in windows7.
i also run Slacko which i find sounds pretty good if a little clunky interface wise. i really must try to get a handle on this Linux thang and mpdvoyager especially.
Korben
you may remember that i'm planing on trying with a 9023 based DAC along with a few other options. So your initial impressions give me a good deal of hope.
really good to hear from you both
Old 9th October 2012, 09:29 PM   #513
Originally Posted by qusp View Post
thanks, yeah thought of both those, probably will go with the second as the first is just as much of a pita as installing win, because you still have to install win. its not a high priority, I already have better USB->PCM/i2s hardware, I only got for DSD tests and have bugger all DSD music, so its no big deal, but its annoying.
I have win in virtualbox already so worst comes to worst just bring it to the headfi meet and I'll bring my imac and we'll get it sorted
Or it can obviously be arranged sooner too.
Old 9th October 2012, 09:47 PM   #514
Ok, I have it working well now. I had an old version of audirvana that wouldn't output DSD, I upgraded it and it is working great. I get voltage on the DSD pins.
Since the firmware upgrade, the crackles in the sound have stopped. I am still using the 'best' firmware with my Buffalo II, I haven't tried the default firmware yet.
Old 9th October 2012, 09:53 PM   #515
Originally Posted by shoom View Post
Korben
Hi shoom
Glad to see you here.
I hope it too, I'll go BAL with Subbu's DAC V3 in I2S mode
Maybe a "HomeMade switchbox" to select from I2S and SPDIF sources too
Old 9th October 2012, 10:27 PM   #516
Originally Posted by korben69 View Post
Hi shoom
Hi Korben
''Glad to see you here''
thanks
Sounds like an interesting project you are starting and it will be interesting to have your thoughts on that once you have it up and running.
For my part I gave up on SPDIF a while ago (well pretty much when I heard what USB I2S could do ) but that’s a personal choice which may not suite others. I'll be using mine with a Teleporter which gives some isolation from PC - DAC grounds and makes swapping between different DAC USB/I2S combinations a breeze. Again not everones idea of a party but works well for me in my set up to my ears.
One thing I have been wondering.
Has anyone tried stripping the 3V3 LDO and using an external PSU to power the Amanero?
It’s sure one of the things that I’d want to try (but only after running the board for a while to make sure that all is well). If the jump in SQ I achieved with errr another USB/I2S board is anything to go by it may be worth trying.
OR
May make no difference what so ever.
But
I’m curious.
Old 10th October 2012, 09:39 PM   #517
greetings,
If anybody tried the iso7640 isolator circuit, are pin 2 and 15 grounded to their appropriate grounds? The schematic does not seem to connect these pins but the datasheet indicates them as ground pins. It would then be easier to solder the .1 cap as these need to be less than 2 mm from the vcc pin.
Hope someone can help.
thanks
Old 11th October 2012, 05:17 AM   #518
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
yes they are, they give you multiple options for routing as well as providing more effective grounding for the device. if you havent bought it already, I would suggest you get either NVE IL715, or SiliconLabs Si8440 both are pin compatible and have lower skew and propagation delay
Old 11th October 2012, 05:34 AM   #519
syklab is offline syklab  Hong Kong
How would you compare the NVE with the TI ISO7240 or AD Adum3440?
Old 11th October 2012, 07:27 AM   #520
@qusp: thanks
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2013 diyAudio
