USB to I2S 384Khz - DSD Converter - Page 31 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 15th September 2012, 02:29 PM   #301
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by Bunpei View Post
The reason why the author of the blog page tried a various bypass capacitors was that the behavior of residual noises was variable depending on USB cabling methods. I think his finding may mean your worries.
correct, thats what is the source of my worries. its only logical too, since there is a direct connection to the USB ground and therefor PC ground, not only that, in this case its used directly for analogue line output ground reference.
I had hoped a transformer would help, but on second thoughts it wouldnt, since its a single ended signal, so any perturbations on ground will still be reflected. its not a common mode error, so even if you can create the correct analogue LPF to get rid of the digital hash in the very high frequency, you will still be stuck with this high ripple on signal ground.
I'm sure there is some way around this, but its not as simple as I had initially hoped
Old 15th September 2012, 03:08 PM   #302
opc is offline opc  Canada
opc's Avatar
I would hazard a guess that you could use fast TTL logic IC's to generate a differential output and run the transformer across that, taking ground out of the equation entirely, and increasing your output voltage swing at the same time.
All you need is a buffer on one side and an inverter on the other.
Deriving the actual analogue audio signal directly from the output of a CPLD terrifies me though. Sounds to me like the worst idea anyone has ever had. Just because something is simple, doesn't mean it's going to be good.
I kinda get the feeling the DIY community is overly susceptible to gimmicks like this because it's so incredibly easy to implement and you get to feel an immediate sense of satisfaction and the "wow it's making music" feeling after having only soldered a single resistor. It's like using the ESS DAC in voltage mode.
Either way, I'll reserve judgement until after I get my boards and measure / listen to it. I have to admit the idea sounds interesting, but I think it will require a little more effort than a 1k resistor to properly implement.
Owen
Old 15th September 2012, 09:01 PM   #303
qusp's Avatar
ya funny you mention that, when I saw Ians new design for the daughterboard to isolate ground between the fifo buffer and clock/buffer board, I had the same idea.
^^post 980 just in case direct link doesnt work
I had the plan of trying this direct out thing with this board as one experiment to do with a cheap device from the beginning, but the idea of just using a resistor doesnt appeal. the idea of a high performance active analogue filter to do it is curious though, given that in native dsd mode thats pretty much all the dac is doing. its a novelty more than anything.
lol bad day at the office mate? agree completely but..... haha I even have a suitable naked zfoil resistor… that should make ground less..erm..bouncy? urushi painted perhaps? (not specifically aimed at Feastrex, i've just noticed that Urushi paint seems to be linked highly with a number of overpriced (but well made) Japanese audio/artisan products lately)
Owen
my thoughts exactly, well...i'll leave the measuring to someone like yourself with the gear/knowhow to make a proper job of it. dsd itself doesnt ever measure that flash afaik, thus why I havent really pursued it till now, so this could be an interesting trainwreck, OR maybe not...
Old 16th September 2012, 03:34 AM   #304
Bunpei is offline Bunpei  Japan
Originally Posted by qusp View Post
... the idea of a high performance active analogue filter to do it is curious though, given that in native dsd mode thats pretty much all the dac is doing. ...
A Japanese skillful audiophile, "sotaro", shows his design idea for the combination of isolated analog FIR and analog Filter. (In Japanese)
Please remember this is designed for DSD256 only. When any of you applies this architecture to DSD128 or DSD64 output of Combo384, you need to recalculate some values.
I'd like to say that DSD256 is constantly establishing its good reputation in Japanese DIY audio communities. I wish Amanero Combo can support this in the near future.
Old 16th September 2012, 08:18 AM   #305
EUVL is offline EUVL  Europe
There is no doubt that a LP filtered DSD signal is the most minimalistic way to do DSD Analog conversion.
And I do use it myself in my old XB940 SACD player.
But don't forget that using the DSD direct out for LPF means you have zero PSRR.
And even if you can make a perfect power supply for your digital source with no noise in the audio band and capable of supply 24 or 98MHz,
there is no guarantee the output of your MCU will give you back 100% that voltage output level digitally.
There is no perfect solution. Else it is too simple. And no fun.
Patrick
xen-audio.com
Old 16th September 2012, 08:22 AM   #306
BTW we had the first batch of the Amanero before the GB.
We tested every functionality successfully without any problems.
We can only say we are very pleased with it.
So our most sincere congratulations to Domenico for a great product.
Nice weekend to Italy,
Patrick
xen-audio.com
Old 16th September 2012, 08:45 AM   #307
qusp's Avatar
Patrick
see the last couple of pages of posts from myself and opc discussing exactly that PSRR issue and possible solutions. good to know you liked the board, I expect mine here any day now
Old 16th September 2012, 08:57 AM   #308
While I give you full credit of pointing out the PSRR issue, I think you missed the key points of my message.
The solution is NOT a perfect power supply for the MCU, which of course does not exist in the first place.
And yes, you can use a Class D amp. Perhaps with lots of feedback and some LPF at the output somewhere.
Patrick
xen-audio.com
Old 16th September 2012, 10:13 AM   #309
NicMac is offline NicMac  Italy
NicMac's Avatar
Patrick
Good to hear. When I first saw the Amanero board I actually thought that it was kind of XEN style. Simple, solid, versatile, but without all the bells and whistles typically seen on these USB converters. It seems that it does one thing and does it well.
Not least, the sound is absolutely impeccable
Nic
Old 16th September 2012, 10:37 AM   #310
Still room for improvement on the hardware side, which we are working on.
(for our team internal PC speaker project)
Patrick
xen-audio.com
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright 1999-2017 diyAudio
