USB to I2S 384Khz - DSD Converter - Page 199 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 10th June 2014, 11:13 AM   #1981
Dear all, now I am using 74vhc244, 74vhc14 to made connection between combo384 and wm8741.
If done, will post it at here.
Old 12th June 2014, 08:04 AM   #1982
Done, now it is work for my DAC now.
Old 12th June 2014, 07:16 PM   #1983
Is GB 7 for Combo 384 still open?
Old 14th June 2014, 03:08 AM   #1984
Hi Domenico,
Have a email to you, please check.
Thanks,
Simon
Old 29th June 2014, 11:52 PM   #1985
mikeg88 is offline mikeg88  Canada
mikeg88's Avatar
can anyone specify a rough 'guide' or give 'instructions' on how to configure the combo384 for a shorter word length compared to the default of 32 bits? I downloaded the OEMtool 1.17 (which seems to be the latest). I don't know my firmware version will permit me to use my combo384 with the OEMtool. The board came shipped with the Rev F datasheet (4/09/2013). Thank you in advance to anyone who can advise!
Old 8th July 2014, 07:56 PM   #1986
Ciao Amanero/Domenico,
Is GB7 still open? would you mind to explain me how to add an entry to it? I would like to get 4.
Ciao!
Old 20th July 2014, 01:37 PM   #1987
Hi everyone,
I also have a problem configuring the Combo384. On the OEMtool 1.15, in the configuration bits panel, I select 24Bit as word lenght as well as DSD channel swap function and then press "write flash". A confirmation message appears saying "Flash Updated!" but as I connect the Combo384 back to my MacMini the interface is still recognized as 32Bit.
I also tried selecting the the 24Bit option before doing a complete refresh of both CPU and CPLD firmwares but I get the same thing. Another user from this forum had the same problem as well as Mikeg88.. I might just write Domenico, hopefully he would know the way around it.
Alex
Old 21st July 2014, 03:26 AM   #1988
aal is offline aal  Russian Federation
can we do to the value of F0 .. F3 feet set in oemtools check buttons, much like in this picture:
http://www.7image.ru/pics/0714/452732684.png
It is desirable also for the input bit depth make a choice (16/24/32 bit) ....
I have a DAC and there ad1853 mode selection DF done with 2 jumpers - it would be very convenient to use ....
Old 21st July 2014, 03:28 AM   #1989
Old 22nd July 2014, 02:58 PM   #1990
merlin2069er's Avatar
Send a message via MSN to merlin2069er
How would I go about powering the Amanero up externally?
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright 1999-2017 diyAudio
