USB to I2S 384Khz - DSD Converter - Page 196 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 4th April 2014, 09:51 AM   #1951
It needs to be implemented in both the drivers and the firmware and AFAIK is not fully implemented yet.
It has been quite a while since firm 1080 (last official) was released, I hope Dom hasn't stamped it "final".
Old 4th April 2014, 12:31 PM   #1952
Thank you for that information. Do you understand how it is meant to work when finally implemented?
Old 4th April 2014, 12:59 PM   #1953
No idea.
Old 23rd April 2014, 10:04 AM   #1954
I will be grateful if someone share his experience with i2c output of the board:
I'm trying to send i2c commands to dsd1974 dac, but unfortunately without success. Is there something specific in the data format of the config tool ? In my case i'm sending per example (copied from the Combo384.ini) :
[OnDSD64]
p0_Address=0x99
p0_Register=0x14
p0_Value=0x30
but these values are not transmitted on the i2c output (i'm monitoring the output with signal analyzer - only few clock cycles and 2-3 bits are going on event) Currently i'm using CPLD and Firmware version 1080.
Thank you in advance!
Old 23rd April 2014, 10:56 AM   #1955
[OnDSD64]
p0_Address=0x99
p0_Register=0x14
p0_Value=0x30
The I2C address in the Amanero needs to be the 7bit equivalent rather than the traditional full eight bit addrees.
For 7 bit I2C address i mean that you need to get the I2C address without the R/W bit example you have 0x90 this is an I2C address composed by
[7bit] +[R/W] = 0x90 in the tool you need to insert as address only the [7bit] part so 0x48
Try 0x4C for address.
Old 24th April 2014, 10:24 AM   #1956
Works like a charm now! Thank you! Cheers!
Old 3rd May 2014, 05:11 PM   #1957
Added myself to the google docsheet list, sent PM to Amanero, hopefully waiting for the answer about payment.
Guys, should I put "mailed" in the google sheet that I've sent PM to Amanero or that stands that shippment is mailed?
Thanks!
Ps. My first post/long time reader
Old 9th May 2014, 08:02 AM   #1958
I have tried to feed my Stello DA100 dac with the IS out of the Amanero but it doesn't work. The alignment/pin-out is correct but still it doesn't work. The lock led is not on and there's is no audio signal.
What could be wrong?
According to the manual 'Stello DA100 Signature takes the IS signals in TTL level.'
Is there a mismatch between the voltage from the Amanero out and the Stello in?
Old 9th May 2014, 10:24 AM   #1959
miksi is offline miksi  Serbia
Amanero works with 3.3v and standard TTL is 5v, so this might be the problem.
Old 9th May 2014, 12:49 PM   #1960
Is there a way to solve this?
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright 1999-2017 diyAudio
