USB to I2S 384Khz - DSD Converter - Page 173 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 20th September 2013, 07:37 AM   #1721
Hi again ...
Thanks for helping out once more
BTW .. to my knowledge a Japanese person/small company (maybe electrart?) makes a DSD principle board that is also available in a 512*fs besides the 256*fs version.
But anyway - my playback chain is not yet at this point - just needed to make sure the amanero board could accommodate both sampling frequencies.
Thanks again
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 23rd September 2013, 07:36 AM   #1722
Default Amanero singing with Salas BIB
Hi, Thanks to Merlin El Mago, who managed to do similar upgrade, I have made this trick, using Salas 1.1 BIB at 5V output. The already good skills of amanero board were elevated to a new level. Finally, I ended up of using just a 3,3V, which is connected to the 3,3 V outlet on the board (near to the I2S outputs). Also an advantage, that the quality of USB cable is less sensitive, because there is no 5V running on it. I have to say, this setup easily rivals the best CD transports. Congratulations to AMANERO and many thanks to MERLIN as well. JŠnos
Originally Posted by DQ828 View Post
I was planning on bringing a permanent 5v power supply to the Amanero as per the image below, basically solder it on to either side of C27 & cut the trace leading to the USB power in.
Can anyone see any issues with doing it this way?
Old 23rd September 2013, 02:20 PM   #1723
hordmop is offline hordmop  Spain
Added myself to the list for 1 pcs
Old 23rd September 2013, 02:35 PM   #1724
i2k92 is offline i2k92  Indonesia
Hi Mr. Amanero,
I'm participant of Quanghao/Andrea DAC ES9018. I've been told that as participant of their groupbuy, we can get discount to buy Amanero USB board.
I've sent email in May to sales@amanero.com and get Paypal notofication to pay, but before I can pay the notification is expired. I've sent another email in August, but no reply. Please tell me what to do to get the discount.
Thank you,
rachmanto
Note: your PM box is full
Old 27th September 2013, 04:15 AM   #1725
mksung is offline mksung  Taiwan
Can I limit the device support 24bits due to my DAC support it but not 32bits? It could cause problem in Linux.
ubuntu@ubuntu-armhf:~$ cat /proc/asound/card1/stream0
Amanero Technologies Combo384 Amanero at usb-musb-hdrc.1.auto-1, high speed : USB Audio
Playback:
Status: Stop
Interface 2
Altset 1
Format: S32_LE <<<< support 32bits only
Channels: 2
Endpoint: 5 OUT (ASYNC)
Rates: 32000, 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Old 27th September 2013, 09:11 PM   #1726
Default Added myself to the list too
Added mz self for 1
Old 29th September 2013, 10:59 PM   #1727
Hello,
Where can I find the group buy? I want to add one for me.
Regards!
Old 30th September 2013, 05:44 AM   #1728
I have a strange issue with my amanero + DAC combination (Quanghao's from elsewhere in diyaudio). All PCM samples are silent but DSD is ok. When PCM is played as DSD, they play ok. Not sure if the amanero is at fault? The DAC locks and has the correct rate. Latest firmware installed.
Old 30th September 2013, 04:10 PM   #1729
gig is offline gig  Italy
Added my name to list (hope GB7 is on...)
Old 2nd October 2013, 12:06 PM   #1730
terranigma's Avatar
Originally Posted by lauc View Post
my card works very well with Windows but I have some problems with a Linux configuration (and a beaglebone card).
Here's the problem log (i think) on an arm ubuntu 13.04 :
ALSA sound/usb/mixer.c:1303 usb_audio: [10] FU [Combo384 Amanero Playback Volume] ch = 2, val = -32767/0/1ALSA sound/usb/mixer.c:1299 usb_audio: Warning! Unlikely big volume range (=32767), cval->res is probably wrong.
The output is louder than windows and noisy (it's like a crappy vinyl record ).
May someone please tell me if a arm linux distribution or a kernel version works better ? (or something to pay attention to )
Thanks.
Same here:
Code:
[   98.018382] usb 3-1.5: new high-speed USB device number 5 using ehci-pci
[   98.107803] usb_audio: Warning! Unlikely big volume range (=32767), cval->res is probably wrong.
[   98.107807] usb_audio: [10] FU [Combo384 Amanero Playback Volume] ch = 2, val = -32767/0/1
[   98.108959] usb_audio: Warning! Unlikely big volume range (=32767), cval->res is probably wrong.
[   98.108961] usb_audio: [10] FU [Combo384 Amanero Playback Volume] ch = 1, val = -32767/0/1
I'm using Linux too. Amanero board has detected but produces this error log and volume control is useless. I'm using latest 3.11 kernel with Arch linux..
@amanero
Do you have tested latest revisions on linux so far?
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
